Question about Sony SDM-HS94P/S 19" LCD Monitor
Hello: Got aSony sdm-hs94p X_BLACK LCD monitor with a white screen when works. The computer detects it, the monitor also starts, but no image can be seen, only a white screen. Can you help me? Thanks in advance Konino.
  • konino Mar 17, 2011
    Hello:
    I've tryed as you suggested, but, it still shows a white screen.
    I have the video card on my hand and it seems everything is in good condition (no burned parts)
    Any suggestion?
    THX !
    President:
  • 2,653 Answers
Can you try hooking the screen up to another computer. A laptop will work too.
This will determine if the problem is with your computer or the screen itself.
Please let me know what happens.
Posted on Mar 17, 2011
  • RescueTechLA
    RescueTechLA Mar 17, 2011
    If you hooked up the monitor to another computer and you still get a white screen than the lcd has a hardware problem. You will need to swap the lcd out with a replacement. BUT before attempting that I would suggest you try a NEW lcd instead of repairing that one.
Monitor picture comes on for only 1 second and then it is blank (black) Color bars appear to be OK (for that second) when running the Self-diagnosis function.
timothy henr, Do you understand how the new screw-in, curlie-Q, energy efficient, CFL light bulbs generate white light?? You will when you find out just what makes the WHITE fixya background on this web page you are looking at!!! Black screen of death can strike at any time!! Do a reply when finished with your research of repair video clips at YOUTUBE. Your search terms are: "lcd monitor disassembly" and "lcd monitor repair." That should get you started. Your unit could have a "switch-mode-power-supply" that detects a problem with itself or another circuit and goes into "full" or "partial" shutdown mode. You should be able to tell the difference if you shine a bright flashlight 1 inch from screen when it goes black!! Partial=still see win-desktop. Full shutdown=no see desktop!!! What wil you do??? Fix or just trade up for new display?? 12fixlouie
Oct 15, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
My sdm-hs73 moniter the power is on but screen is blank, what could be wrong
First check brightness and contrast settings.
If all good could either be your lcd back light has gone or the inverter. To check if its the black light shine a torch through the back of the screen to see if you can see a slight image on it, if you cant see anything the inverter board is faulty and to repair needs to be changed.
Jan 21, 2010 | Sony SDM-HS73P 17" LCD Monitor
Screen turns on for a few seconds then goes black...
mhaupt, Tell me if it is both BLACK and BLANK or just BLACK after you do the flashlight trick !!! This is no joke!! understand?? When the screen goes black hold bright flashlight where you saw an image on the screen (icon or win start button) and tell me what you see or don't see!!
Get back to fixya with new comment to your original post. 12fixlouie
Oct 27, 2009 | Sony SDM-HS73P 17" LCD Monitor
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
Green tones
try to update the lastest version for your video card driver.
May 12, 2009 | Sony SDM-HS94P/S 19" LCD Monitor
Screen went black
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. You have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside. Some of them were broken and it is very easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. You might go get technician to do fix it.
Mar 06, 2008 | Sony SDM-HS75P/S 17" LCD Monitor
Sony SDM-HS74P/S 17 - Monitor won't stay on the right picture
When the screen turns black again take a flashlight and shine it in the bottom left hand corner where the Windows Start button is located. If you can see a faint image then your back light is failing. If that?s not the case the next step would be to attach another monitor to your computer to see if the problem disappears. If it does that points to the monitor, if it doesn?t then we need to take a look at the computer itself. Let us know what you find out and please don?t forget to rate this posting.
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Sony SDM-HS74P 17" Monitor goes black after turning on
Most likely you inverterboard went bad on the monitor.
Nov 04, 2006 | Sony SDM-HS74P 17" LCD Monitor
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
Sony SDM-HS94P/S 19" LCD Monitor Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
