Question about Zyxel P660HWD1 v2 WirelessADSL2+ Gateway Router
We have a samsung NC10 Netbook with wireless connectivity problems. Other laptops connect. We would like to manually allocate the IP address and would like all the details to do this?
  • Zyxel Master
  • 7,733 Answers
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Posted on Mar 18, 2011
Acer netbook d257 limited or no connectivity
If you get a 'Limited connectivity" on your wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Feb 26, 2013 | Toshiba Tecra 8000 Notebook
Sylvania7'netbook
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
Aug 12, 2012 | Acer Aspire One AOD150-1920 Netbook
I have an Acer laptop computer that stopped being able to connect to wife all the way. It says I am connected but then tells me I have limited or no connectivity. Why?
This error occures when your laptop has not been allocated an IP address from your wireless router.
To fix this, right click on your wireless connection on the Task bar and click Repair. The wireless router will then issue a new IP address to the wireless card in your laptop.
Jan 27, 2012 | Acer Computers & Internet
Wireless wont connect on samsung n130 netbook keeps saying searching foe ip address but never gets that far
Hi, I presume your connecting to your home wifi router, if so try deleting your password/connection settings for it and start a fresh connection
Oct 28, 2010 | Samsung N13013B Netbook
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
How do i setup my internet on the samsung nc10? i am wirelessly connected but when i go into networks it says te local connection is not connected because the network cable is unplugged but i dont have a...
Local area connection is meant for wired LAN connection. you can connect the internet using a straight clable wire.
on how to make a straight cable,below is the link
http://www.ertyu.org/steven_nikkel/ethernetcables.html
But as you have said you can connect using wireless,then in wireless adapter setting,
Assigned your IP address Plus Subnet Mask address.
Set your wireless access point IP address as your Default Gateway Address.
In Primary DNS address as provided by your Internet service provider.specify secondary address too,it available.
If DHCP server is available then you don't need to configure anything.
If you are trying to browse internet through a proxy server than Go to internet Explorer,Click "Tools", Select "Internet options ", Select Connection, Tick Proxy server and specify the IP address of your proxy server and the port.
you will be able to browse Internet now.
Rate this answer.
Dec 27, 2009 | Samsung NC10-14ROBL Notebook
Samsung nc10 netbook will not connect wireless network
I know you posted this a long time ago (5 or 6 months), but just for future reference with other having this same problem or if you just gave up on connecting it wirelessly, here's the scoop. The Samsung NC10 netbook will not connect wirelessly and will sometimes tell you to make sure the the Wireless Switch is "On". However, there's no indication of where this magic switch is. I looked all over my keyboard, the casing, etc. I feel foolish now, but at the time I thought surely there existed an obvious switch. NOPE! The switch is located in "Change Network Settings" or something like that, sorry I don't have the computer right in front of me (I prefer my MacBook). In the window that opens, first thing you will see is your wireless network card listed and a button next to it that says "Configure". Click the "Configure" button and when the window changes you will be able to switch your wireless connection from "Wireless Off" to "Wireless On".
Dec 24, 2009 | Samsung Tablets & eReaders
Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Aug 20, 2009 | Samsung NC10-14GW Notebook
Wi-Fi not connecting on Toshiba Satellite A15-S157 PC Notebook
you tried giving it a static IP address rather than using automatic settings (i.e. DHCP). Sure enough, this cured the problem, connected fine. I looked in the dhcp server logs and while it was not complaining that the IP address pool was all used, it did seem that all the IP addresses available were being used. I increased the number of IP addresses available to be allocated by the dhcp server and problem solved. The big mystery to me is why Windows XP would report this as a problem with a weak signal? Isn't the access to the dhcp server and the allocation of the IP address at a layer above the wireless connection? Anyway, it's useful to be warned that the wireless diagnostics are misleading.
Nov 05, 2008 | Toshiba Satellite A15-S157 Notebook
Laptops do not recieve IP address from the router
Carlos
I think the problem lies within the dhcp of your router. Make sure dhcp is on and change the lease time to 1440 minutes or higher that way once you have the ip address it will stay with your laptop longer. alternatively allocate the ip address on your laptop manually.
good luck
smeags
Jan 03, 2008 | Trendware TEW-452BRP Wireless Router...
Zyxel P660HWD1 v2 WirelessADSL2+ Gateway Router Logo
91 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
