Jumps all over the place while tying. - Computers & Internet
    Guru:
  • 78 Answers
Hi-
Here's a quick fix to your concern:
Click and Install this particular software: Touchfreeze
Touchfreeze will disable your touchpad sensitivity while you are typing something.
Hope this helps..
Good Luck!
Posted on Mar 17, 2011
My Janome 8050 bobbin case is jumping out of place. The thread is wrapping around the bobbin case and getting stuck, bunching up, and shutting down my sewing progress. It ties the needle up.
check for the retainer action of the bobbin case to see in there is a part broken off that holds the bobbin in the case or carrier
from what you describe , with the thread bunching up etc, I suspect that the needle thread tension is too loose and causing the problems
if so then the bunching and problems can be from the bunched thread pushing the bobbin out of position
take it in for a service and if necessary , repair
Dec 20, 2016 | Janome Sewing Machines
I have a duotherm AC unit. Which two wires do I jump to bypass the thermostat
Hey David if you are wanting to bypass the thermostat to make the air conditioner come on you would take r which should be red and y which should be yellow,. Tie them together. This gives the outside unit a constant 24volts( call for cool). If it is a heat pump you would also want to take o which mostly is orange and tie them with the red and yellow to energize reversing valve. If not it will be jumped out but be in heat mode. R to w(white) would turn your heat strips on. If your thermostat is bad and you plan on leaving it like this temporarily also take g (green) and tie it to red and yellow. G is your inside fan. Basically r is your 24volts so you tie it to what u want to jump out y= outside unit o/b=reveesingvalve if heat pump g= inside blower w{ inside heat strips. C is common never jump c to r or you will blow a fuse or transformer only reason you would have c at thermostat is so it can run without batteries. Hope this helps
Oct 24, 2016 | Heating & Cooling
Ball joint bolt fell out upper in 2007 GMC Envoy
Upper ball joint? That's not related to the job of replacing a tie rod or tie rod end. It's also not related to the brake job.
It's an '07 and it had a bolt-in ball joint? That's not factory - it's been replaced before.
Aug 07, 2014 | 2007 GMC Envoy
I just bought the Weider Beaded Jump Rope and it is too long for me is there a way to shorten it without ruining it?
if you're careful and crafty you can try to take the beads off the rope and use a scissor to cut the rope to your ideal height, If the jump rope isn't constructed to be disassembled or you don't wanna take the risk, try tying a knot on both end of the handles to shorten the rope. btw you probably know this already, but when trying to determine the length of a jump rope you should stand on the center of the rope and make sure each end of the handle reaches your armpit or at least your chest
Jan 16, 2013 | Weider Jump Rope, Beaded, 1 rope
Tach jumps all over the place driving and idle. works correct sometimes. how to repair?
crank sensor is tied in with the tach. you have problem with crank sensor or electrical problem. the tach reads rpms, if the sensor is bad it throws the rpms way off. this is why you get the jumping in gauge.
May 28, 2010 | 1993 Nissan Pathfinder
How to change the inner tie rod, as the existing tie rod has place for a wrench
Tie rods are replaced from ball joint to ball joint, the place for the wrench is to adjust wheel alignment toe in. Ball joints are removed with a special fork, you can sometimes use a hammer to shock the taper and remove them.
Apr 17, 2010 | 1999 Dodge Grand Caravan
Will broken rt tie rod make rt front of truck jump up and down or do i have a drive train problem
with a broken tie rod your front wheels will not be starigtly aligned no longer and inoperateble to drive it 1 foot. A broken coil spring will make a vehicle bob up and down for sure.
Mar 13, 2010 | 1998 Ford Explorer
How do I get the tie rod linkage lose from the steering universal joint? I took the bold out but it sitll wont break free
The tie rod comes out of the spindle,by slamming the surounding area with a hammer,not the tie rod,and not the threads on the tie rod,where the stud of the tie rod go in the spindle,hit it with a hammer,on the spindle,not the tie rod,hit it hard,multiple times,the tie rod will almost jump out.
Feb 27, 2010 | 2007 Saturn VUE FWD 4
2000 LINCOLN LS - Outer tie rod removal assistance
Yes degreaser will not hurt it. The outer tie rod is retained only by one nut that connects it to the inner tie rod.Once you have this loosen just turn the outer tie rod to the left to remove it from the inner tie rod.
Feb 24, 2010 | 2000 Lincoln LS
Belt on a hotpoint wf250
open it up, see wat thensions the belt, loosen that up and fit new belt. retension
Apr 19, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
