Every time I log on I get an error message relating to my sumvision 2.5 sata to usb 2.0 external hard drive. The message is E:Desktop refers to a location that is unavailable. It could be on a hard drive on this computer or a network. Check to make sure that the disk is properly inserted, or that you are connected to the internet or your network, and then try again. If still can not be located the information might have been moved to a difternt location. I have tried to find the drivers on on line and can not. Thanks Michelle
    Sergeant:
  • 197 Answers
Http://www.solvusoft.com/en/update/drivers/usb/sumvision/egem-2-5-sata-to-usb-aluminium-enclosure-grey/sub-models/
That's the driver - BUT--- unfortunately this sounds to me like a registry error where you will need someone with a fair amount of computer experience to edit registry correctly...what is happening is that your drive is not recognized as its like a person on a plane sitting in the wrong seat...there's a role call... and then ERROR! and the computer spits it!
Posted on May 06, 2017
    Master:
  • Computers & ... Master
  • 604 Answers
An external hdd is not the same as a network or memory in a computer,it can only be accessed by a human,not automatically when you log in,if you have files or drivers on it,you need to put them on the computer.
2 Suggested Answers
ib_yang
  • 1098 Answers
SOURCE: Our Notebook LG x 140
Reboot repeatedly tapping F8 - select last known good configuration.
If no help try System Restore back to a point before this happened. You can do this from Safe Mode
repeatedly tap F8 as you boot - select Safe Mode.
How to Do a System Restore in Vista
If still no help do a Startup Repair - if no Recovery Options or Vista disks then you can borrow one as they are not copy protected.
This tells you how to access the System Recovery Options and/or with a Vista Disk
How to do a Startup Repair
Most cases, what causes this is an anti virus software. Try to uninstall the anti virus and reboot see what happens.
Hope this helps.
Posted on Sep 02, 2011
The power light is on, it isn't running, and it is not connectiong to my computor. This has all my kids pictures on it.
External hard drives of this type are mainly composed of a USB-to-SATA interface & a 2.5" SATA hard drive. If any of these components is defective, then you won't be able to access your data.
So, basically we have 2 possibilities:
1. A failing USB-to-SATA interface. You can test this possibility by disassembling the device, taking the hard drive out, & testing the hard drive in your desktop computer using a 2.5" to 3.5" SATA adapter. If the hard drive works fine, then the problem lies within the USB-to-SATA interface.
2. In the previous step, if the hard drive could not be detected by your desktop computer or is not working properly, then it is the failing part.
Aug 31, 2011 | SimpleTech Computers & Internet
I'm trying to install a Western Digital Serial ATA Hard Drive into the external hard drive enclosure. There are no instructions as to what cables need to be attached and to where
USB external hard drive cases are supplied with SATA and power connectors attached to the circuit board in the case. If you canot connect it to the SATA hard drive then you may have the wrong drive case, your case may be a IDE or SCSI type.
Jul 07, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
Got a Sumvision External 2.5 Hard drive for over a year now and today i pluged it in as normal and got the following error messages - using windows 7 also tried it in XP and it doesnt recongise the hard...
Hook up that external hard drive to another computer that you know for sure the USB ports work properly. If you still get the same error message or the drive is not recognized then that means the hard drive is bad.
If the hard drive is recognized properly and you can access the files then that means its an issue with the operating system.
May 14, 2011 | Computers & Internet
I have a Dell desktop running Windows Vista. I cannot boot up to Windows. I have a black screen with cursor error message saying: boot device available, ta 0 installed, ta 1 installed, ta 2 none, ta 3...
That message says that the hard disk was found but nothing on it can be used - Vista is completely corrupted. You will have to reinstall it using the recovery cd that came with it when you bought it.
Feb 02, 2011 | Dell Inspiron 531s Desktop Computer
How to change hard drive
change your hard drive by replacing another hard drive with ide a belt type one end to the mother board and other end to the harddrive..... then another wire that comes from your smps box in your cabinet with red blue green colours connect it to your hard drive thats it..
if your harddrive is sata then do the same in the sata
Jul 03, 2010 | MPC Computers (9052701) PC Desktop
I cannot get an external hard drive to work on mac
sounds like the Hard drive is not formatted for the MAC
Mar 23, 2010 | Computers & Internet
External Hard Drive I/O Error
Somehow i tried to format and it was formatted. took pretty long time as 1 terabyte. i thought all is ok as the drive was accessible. Just to double check, i scanned the drive thorugh the seagate manager and it got stuck on 10% for few seconds and then said that the hard disk is faulty and should be immediately returned if under warranty. and to confirm it also gave me read errors http://www.dtidata.com/resourcecenter/2007/05/15/how-to-tell-hard-drive-physical-damage/
so i'm giving it to seagate service centre as it probably has physical faults, bad sectors. and someone told me that 1TB hard drives are not stable.
Jun 18, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Hardware Malfunction Error
Hi, This is a common problem with external storage. Please refer to http://www.fixya.com/support/t191153-device_recognized Below is a copy of my response to a similar post. Based on your post/description: 1. Your PC does not recognize the external hard drive via its USB connection - try on a different computer - if it is still a no go, then it's not a PC problem; 2. Try replacing the cable - again if a no go, so it's not an interface/cable problem; 3. That leaves you only with the My Book itself as the possible at fault. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options aside from running manufacturer's diagnostic and/or third party recovery software are: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it direct inside a desktop either as IDE or SATA; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Sep 04, 2007 | Western Digital My Book Essential Edition...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
