Question about Zanussi Washing Machines
After machine has finished cycle and is not used for a day water refills in drum although its empty and door open
    Brigadier General:
  • 6,277 Answers
This is symptomatic of an intermittent (hot, if it's both hot and cold fill, cold if it's cold fill only) water control valve. Its physical no power/fail position is closed but yours is not closing completely. It needs replacing so sorry, service call ;-0(
Good luck,
John C
Posted on Mar 17, 2011
Testimonial: "thanks for the quick reply will contact engineer tomorrow"
Haha machine not finishing cycle cannot open the door and full of water
use gravity to empty the machine
a bucket might not be low enough
make a longer hose to reach outside the house at ground level
or lots of towels
drop the water outlet pipe to the ground and bowl will empty
the door should open
after that possible timer repair or control board replacement
Jul 17, 2016 | Washing Machines
Door will not open if machine not emptied immediately cycle ends
This is an anti-flood protection, since water would flood the kitchen if you could open the door. If the machine shuts down for some fault and leaves the drum with water in, then it is advisable to drain the drum down via the small hose at the front of the machine. Simply remove the plug and empty into a large container until the drum is empty. You can then start to work out why the cycle ceased prematurely.
Mar 08, 2015 | Miele Washing Machines
I can't unlock my washing machine, I don't know why. It normally opens automatically after it has finished.
Apart from a faulty Door interlock could be water stiil in the drum make sure its empty and electrics are ok firstly
Feb 22, 2011 | Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
The door will not open, and the cycle hasn't finished as possible fault with machine. How can we open the door?
take your outlet pipe and lay it into a bowl low to floor, this will cause water to empty, unless there is a blockage.when empty door should open.
Feb 16, 2010 | Washing Machines
Washing machine fills with water when not in use.
Either your pressure in the main line bringing water to your machine is insufficient; or your intake water valve is defective; which you can replace easily.
Feb 22, 2009 | Asko Washing Machines
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
Sep 14, 2008 | Hotpoint WMA64 Front Load Washer
You have an open solenoid on your water valve where the fill hoses connect. Change the water valve and you should be good.
Jul 25, 2008 | Washing Machines
Click on washing machines above, (below FIXYA) on this site, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site. You have to replace your inlet water valves. Its simple.
Feb 11, 2008 | Washing Machines
Washing Machines Logo
83 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
