Question about Porcher 5535-254.___ Reprise Pillar Taps Bath Faucets w/Cross Handles
My bathtub hotwater faucet wont turn off completely and its causing a constant trickle of water -is it the washer maybe.?
  • 3,640 Answers
Sounds like the washer in handle needs replaced.
Posted on Mar 17, 2011
Cold water trickling into washer - what would cause this?
CHECK AND SEE IF THERE ARE SCREENS AT THE WATER VALVE IT MAY BE CLOGGED THERE
Jun 18, 2014 | Frigidaire CWS3600AS Top Load Washer
Tub faucet (hot side) won't turn off when tight and the shutoff valve won't stop the water either
sound like you need a new valve in the hot water Faucet the rubber washer or cartridge depending on what type of faucet you have
May 09, 2014 | Sunrise Specialty Cast Iron Claw Foot Tub...
Water Will Not Turn On
shut off water to tub. remove the faucets one at a time. maybe the faucet washers on the bottom of the stems came off.
Nov 07, 2011 | Home
Cold water faucet drip. Took apart fausect, no visible sign of wear. Faucet is only seven years old. Does faucet have a basin washer that may be worn ?
Hi bobwiz...
Your faucet may be leaking because of a bad seat that the rubber/plastic washer seals on...
Check the seat condition for wear, especially a "line cut" in the brass seat from where the water has eroaded the seat, this could cause your leak.
If the seat has a "line" cut in it, then you will need to purchase a seat repair tool from your local hardware store and refinish the seat.
Check and replace your plastic/rubber washer, it is 7 yrs old and maybe hard and not seating properly.
Please take time to rate me
Aug 17, 2011 | Delta Home
We are getting a constant drip through the faucet when both taps are turned off. please advise solution
Hi mark stopfor...
Sounds like the sealing washers are in need of replacement.
Look under the sink and find the shut off valves to the faucet.
Shut off water, remove handles from faucet, then use a wrench to remove the insert that holds the sealing washers. Replace the washers with new ones that you will have to purchase and reassemble...that should solve your leaking faucets...
Free Answer...Please take time to rate me.
Jun 13, 2011 | Home
I have a single control, new glacier bay bathtub faucet control. i don't have the hot water heater hooked up. i'm only getting a slight trickle out of my faucet whenb i turn the knob to cold. is it...
it is likely required. many new faucets have what's called a pressure balance valve that helps prevent scalding by lowering the pressure of hot when the cold pressure drops (due to a toilet flush or other water being run). Because you have pressure to only one side, that can cause the valve not to provide the necessary volume.
Dec 12, 2010 | Plumbing
Bathtub faucet only runs hot water. think it is hardwater problem because this faucet is closest to the waterheater. Other bathtub faucets in the house do not have this problem. Part of my water source...
there should be alternate little faucet knobs somewhere close one hot one cold, maybe you just have the hot knob turned to the maximum
Aug 29, 2010 | Moen Home
Leaking hotwater from the tap
You have two options. You can either replace the faucets- which is much easier for a novice, or you can rebuild them. As far as removing the handles, double check and make sure there is no set screw. If there is not, then the handles should come off. You may have to gently rock each one from side to side. Once you get the handles off, you should see where the valve unscrews. Now would be a good time to turn off the main water going to the tub. Once that is done carefully unscrew the valves and remove them. Take this to Lowes or Home Depot and you should be able to find repacking kits. They usually have full installation instructions included.
Sep 27, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Roper washer wont Agitate
you have a bad watwer inlet valve but the agit. has nothing to do with the water unless you are not getting enough into the machine to start the agit cycle
Jul 29, 2008 | Roper RAB2121KW Top Load Washer
Porcher 5535-254.___ Reprise Pillar Taps Bath Faucets w/Cross Handles Logo
140 people viewed this question
Top Porcher Plumbing Experts
Donni Steen
Tom Chichester
Are you a Porcher Plumbing Expert? Answer questions, earn points and help others
