Question about Intel 845GE Motherboard
Vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
What should i do
  • ankitsinghal Aug 02, 2008
    vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
  • 152 Answers
Replace it i can provide you
contact to my email id ariescomputersolutions@yahoo.com
Posted on Mar 10, 2009
    Scholar:
  • 68 Answers
You should either change the ic......or if the problem persists.....i suggest you to give it in a repair shop....so then only it can be solved......the problem can be in the motherboard also....i am a software engineer and i have experience in it ....thats why i am suggesting you this way....try this....it will 100%
Posted on Sep 19, 2008
Motherboard will not post no video either if i have the 12v 4pin cpu plug in its socket the pc just starts and stops in a loop
The motherboard is stopping while you connecting the 12V 4pin connector because of VRM short circuit (Voltage Raiser Module, CPU V-Core circulatory). Contact Nearest Gigabyte support center for support.
Feb 12, 2011 | Gigabyte GA-EP43-DS3LR Motherboard
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
4 pin plug 12volt on the motherboard.
pls you have to identify which area is short circuit, there for remove the 4 pin plug and power on. of power on ,it is telling your cpu section (VRM Circuit is short) it may faulty cap or transistor , bit I found more than 80% is shorted north bridge.
it was not fixed. but you have to test all coils to identify which section mos fets are short, remove the cpu to isolate north bridge , check vrm circuit,
images?q=tbn:and9gctvnhhmvqm60iuldruuri-bndxickpzhgxm7juwfsizc3gdj9_-4a
Aug 26, 2017 | Intel D945GTP Motherboard
ADP3168
Here is a link to download the data sheet.
http://www.digchip.com/datasheets/download_datasheet.php?id=121921&part-number=ADP3168
Dec 29, 2008 | Intel D845GVSR Motherboard
Adding second CPU
Hi
Did you receive a VRM with the the PRC upgrade kit? And have you installed it?
The following items are/should be included in a microprocessor upgrade kit:
• A microprocessor (PRC)
• A heat sink
• Heat-sink retention clip(s)
• A voltage regulator module (VRM),
Your upgrade kit may also include a cooling fan.
If you are adding a secondary microprocessor, examine the VRM to ensure that it is the correct VRM for your system. Install the VRM in the appropriate secondary VRM connector, ensuring that the latches at each end of the connector engage. If you received two VRMs with the upgrade kit, replace the primary VRM already installed in the system with one of the VRMs from the upgrade kit.
Note: The system does not support mismatched VRMs.
Check PE1600sc Microprocessor Upgrade Installation Guide - http://support.dell.com/support/edocs/systems/pe1600sc/multlang/proc/9D904A05.pdf
Let me know how you get on
Mike
May 13, 2008 | Dell PowerEdge 1600SC Server
Your solution re motherboard
"voltage regulator module" thats have next to core voltage connector it's supply to cpu
cpu need 2 volt 45 amp and our power supply can produce voltage 12 volt 3 amp so motherboard can produce more amp for cpu . 6 mosfet using for this process it's near by cpu
Apr 11, 2008 | Intel Motherboard
Please help
if your cpu can't heat so your mobo vrm circuit fail ic no: adp3168 near by cpu
Mar 29, 2008 | Intel D845GVSR Motherboard
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Ga-7N400E powerup problem
VRM Circuit problem found there
disconnect only core voltage connetor and power on motherboard
if motherboard on so confirm that your vrm circuit is sort
replace vrm circuit mosfet
Feb 23, 2008 | Gigabyte GA-7N400E-L Motherboard
Intel 845GE Motherboard Logo
668 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
