Turns on and off repeatedly every 10 seconds - Televison & Video
    Scholar:
  • 126 Answers
Sounds like a power supply problem. - open the back check the power supply for busted/leaking or swollen caps - replace them with new ones - do not use the 85degree ones from radio shack - order them off the net and get the 105degree ones so they will last longer .
thanks,
michael
Posted on Mar 17, 2011
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
How to program avital 7143L keyless remote to a 2007 Chevrolet HHR Lt?
Turn the key on without starting it leave it on for 10 minutes then turn it off for 10 seconds repeat it 3 times if you let it go for more than 10 minutes your going to have to start again it's got to be right on the money 10 min on 10 sec off remberm 3 times
Sep 10, 2015 | Chevrolet Cars & Trucks
Pass lock system
There is a resistor either in your key, or your ignition switch on the steering column. A resistance value is sent to your BCM (body control module) - which is programmed to accept a certain value. If this resistance changes; because of corroded wires, a degraded or changed resistor, or changing your key lock cylinder - you've got to do the relearn procedure.
Step 1 - Attempt to start the vehicle. It will crank, but not run. The security light will be flashing on and off. Leave the key in the 'run' position for exactly 10 minutes, then the security light will stay solid or go off.
Step 2 - Turn the key to the 'off' position for 10 seconds. Attempt to start the vehicle. Some vehicles will run at this point, although many will require you repeat repeat Step 1 two more times. Make sure turn the key to the 'off' position for 10 seconds before each 10 minute cycle.
Step 3 - The vehicle is now ready to relearn the proper code. Turn the key 'off' for 10 seconds and then 'crank' the vehicle. It should be running now. The security light might stay on solid for several minutes afterwards, depending on your system.
Depending on the problem you are having this may help.
Sep 18, 2013 | Chevrolet Cars & Trucks
How do i program a new keyless remote for my 2002 Suzuki Aerio?
. Remove key from ignition switch.2. Close all doors.
3. Open drivers door
4. Insert key and turn to ON position and within 10 seconds turn
key off and remove key.
5. Within 20 seconds Close and open drivers door 3 times.
6. Insert key and turn to ON position and within 10 seconds turn
7. Locks should now lock and unlock automatically to confirm you
have entered programming mode.
8. Press the UNLOCK button on remote and locks should cycle to
confirm programming.
9. Repeat step 8 on each additional remote.
10. Exit vehicle with keys and remote, close door test remote(s).
Jul 13, 2012 | 2002 Suzuki Aerio
Trouble turning the tv on
I will need the model number of the set in order to assist with the issue
Nov 22, 2011 | Magnavox Televison & Video
Theft system 2000 malibu ls
try this: turn key on, crank starter for 1 second, leave key on for 10 minutes. after 10 min. shut key off and repeat 3 times. (on second try, crank a sec. or so longer, the reprogram may take off right away. if not, repeat make sure battery is strong, key could be on for 1/2 hr. sometimes engaging emergency brake before key is turned on prevent daytime running lites to come on to save battery power (if equipped). been through it, thought i'd mention it
Nov 16, 2008 | 2000 Chevrolet Malibu
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Nov 03, 2008 | Nextar MA933A MP3 Player
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
