Question about Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM TR069 & INT P - 6218-I4-200 Wireless Router
I have a Zhone router, model number 6218-I4-200-0CL. I'm trying to figure out how to forward a port, but there is no actual "Port Forward" option under the configuration options. There is "Port Trigger" but it doesn't seem like that's the same thing. Would really appreciate some help.
  • Rachel
    Rachel Mar 17, 2011
    I added that port as an exception under my firewall a while ago. I tried turning the firewall off, as well... Still no beans. I'm pretty techy when it comes to computers, and this... it's just driving me absolutely up the wall. Doesn't make any sense.
  • 977 Answers
Hi!
Please follow the guide here... It's for a different Zhone model - but it should work exactly the same!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Posted on Mar 17, 2011
  • 2 more comments
  • Rachel
    Rachel Mar 17, 2011
    Well, the configuration window looks exactly the same, but it doesn't seem to be working. I'm using the PortChecker from the same site you linked to, and it says it can ping my router, but the port isn't open/reachable.
  • Ran Kedar
    Ran Kedar Mar 17, 2011
    Make sure Windows Firewall is also set to allow traffic from/to that port; Alternatively, turn Windows Firewall off. Do the same for any other firewall software (If exist) on your computer.
    Pelu.
  • Rachel
    Rachel Mar 17, 2011
    The port has been an exception on the firewalls settings for a while. Turning the firewall off doesn't seem to fix it, either.
  • Rachel
    Rachel Mar 18, 2011
    Now I'm having yet another issue--I can't access the configuration page http://192.168.1.1/) at all. Was working earlier, obviously... Now it returns a "This webpage is not available" error. This router is epic fail.
    Scholar:
  • 155 Answers
In many router is under the function of virtual server, in your case it looks like the Zhone people has put this function under Firewall - IPFiltering - Incoming.
Let me know if you need more help.
  • 3 more comments
  • Rachel
    Rachel Mar 17, 2011
    I'm sorry, I don't even see IPFiltering on my configuration screen. I see Firewall, but the only options under it are Parental control and URL Filter.
  • Massimo Ardito
    Massimo Ardito Mar 17, 2011
    You are right, my mistake.
    By looking more in depth I understand that you have to enable NAT and then you can create virtual servers.
    Please let me know.
  • Massimo Ardito
    Check this link, page 49 and 50
    http://www.zhone.com/support/manuals/doc...
  • Rachel
    Rachel Mar 17, 2011
    I'm sorry, I'm slightly confused--are you saying that I should set up a virtual server in order to forward a port??
  • Massimo Ardito
    Massimo Ardito Mar 18, 2011
    Yes, absolutely.
    If you want to forward a port in some router is called port forwarding (Netgear) in other one virtual server (Belkin).
    Please go to your router configuration, enable NAT and then select Virtual Server.
    Enter a name easy to remember in the field Custom Server or you can select some of the already pre-configured proposed if you find what you need.
    Then in the field Server IP address put the name of the PC you are trying to forward your port for example 192.168.1.10
    Now select the external port start and end (It could be the same value if it is only 1 port) and then enter the internal port start and end.
    Do not forget to choose the protocol if it is TCP or UDP or both.
    Click Save/Apply and you are done.
    Here an example of a possible configuration for:
    UltraVNC
    192.168.1.(Your PC) 5900 5900 TCP 5900 5900
    FTP
    192.168.1.(Your PC) 20 21 TCP 20 21
    eMule
    192.168.1.(Your PC) 63940 63940 UDP 63940 63940
    192.168.1.(Your PC) 63930 63930 TCP 63930 63930
    I hope this can help, otherwise let me know.
Need to open port on my 6218-12-200-0CC router for xbox live but dont know how
2 ways you can do this. <br /> 1. Connect to your router 192.168.1.1. Go to advance setup, NAT settings, then virtual servers. Click ADD, you will be at a setup screen now, click Select Service and choose xbox live. Then type in your ip address just below (192.168.1.1) and click save/apply, thats it.<br /> 2. Go to this site, <a href="http://www.portforward.com">www.portforward.com</a>, go through the motions and selct your zhone 6218 modem. Follow the directions they have listed.
Aug 08, 2010 | Zhone (6218-I2-200) Router
Need to change the NAT setting on my Zhone 6218 DSL modem. How?
try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection through control panel > network connections.... if you get the ip adress in the range of dlink router then try going to start > run > type "cmd" and hit enter >command prompt will appear... in command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
Jul 16, 2010 | Zhone (6218-I2-200) Router
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
When using utorrent or any other torrent client it says i have problem with my network configuration
You'll need to forward the port you have selected in your BT client (you can set it / checj ut in uTorrent: Ctrl+P -> Connection -> Port used for incoming connections. It should be something between 40000-52000.) to accept incoming connections.
Unfortunatly there is no guide for your router model, but you can help with this one http://www.portforward.com/english/routers/port_forwarding/Zhone/6218-12-200-0TT/6218-12-200-0TTindex.htm, also port forwarding is referenced in your owners manual, so you should check that too.
Mar 21, 2009 | Zhone (6218-I2-200) Router
Zhone 6218
To restore the router to factory default settings, select Management ->
Settings -> Restore Default.
I take it that is what you have tryed?
http://zhone.com/support/downloads/cpe/
try finding the correct firmware to install
Aug 12, 2008 | Zhone (6218-I2-200) Router
I dont know???
there's no port forwarding option on this manual (go to page 51) but it has port triggering and dmz. you can use both if you only want to open the NAT of your router
hope this'll help you
ciao!
Aug 11, 2008 | Zhone (6218-I2-200) Router
NAT? Where?!
Perhaps you are using a different firmware than the one they are using in the guide. If they are using an older one then you may just need to figure it out. Look through your router's settings again for anything that mentions NAT, Port Forwarding, or Virtual Server. Then just pick the port (or ports) that you want to forward and which machine to forward them to.
One last thing that may be causing your issue is that you are not connecting to your router. Does the configuration page that you visit display your routers make or model? If you have a modem and a router, then it's possible you are actually connecting to your modem instead.
May 13, 2008 | Zhone (6218-I2-200) Router
Port Forwading
Go to your routers setup page,
Go to the section labeled port range forwarding, then enter the information.
Apr 04, 2008 | Zhone (6218-I2-200) Router
Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Dec 24, 2007 | Zhone (6218-I2-200) Router
Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM TR069 & INT P - 6218-I4-200 Wireless Router Logo
651 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
