We have the smeg retro 50's flueless fire on our lounge wall but it is causing the paint above to bubble and crack, is there a solution to this?
    Brigadier General:
  • 4,736 Answers
Daniel, from what you have described, it sounds like the catalytic converter inside, near the top of the unit is overheating. It may simply need cleaning due to dust collecting in it or depending on how old the unit is, it may need to be replaced. In case you may have misplaced your Owners Manual, I have included a link to it that you can download and print. This may help your do further troubleshooting,
http://www.smegtech.com/site/smeg/pdf_libretti/L23-30_P23_Fire%20instr-GB.pdf
Until the issue is resolved, for safety's sake, I highly recommend that you discontinue using the fireplace.
Hope this helped you?
Posted on Mar 18, 2011
Paint bubbling and peeling soon after painting a newly rendered wall........how do we fix it?
Sorry for the paint peeling and bubbles. It's not the drywall tape that has bubbles... right? Paint can react like this when it is applied over a sanded wall that has not been cleaned and still has a layer of drywall dust on it. When primer is applied to the wall, it is best to use something to push the paint on the surface to combine the dust with the paint. This could be done using a paint pad but should be more than just rolled on. The paint needs to mix with the dust and stir it in with the paint so the paint get under the dust. You might try thinning the paint a little to allow for better attraction to the wall. So now how do you repair this? By scraping the loose paint off and starting with a new coat. You know. it could also just be bad paint.
Aug 02, 2014 | Drywall
Paint bubbling
Cure the damp problem and re paint it.
Jul 14, 2014 | Air Tools & Compressors
Is recycled paint good for walls
generally speaking if the lids have been left on tight and you strain the paint with a stocking it will be ok but it might not smell to pleasant for a few days.try dropping in some perfume to kill the smell or a tea spoon of bleach will do suffice.
Jun 25, 2014 | Tools & Hardware - Others
Paint bubble over drywall patch
NO...Cut out the bubble, respackle, then paint.
May 05, 2014 | Tools & Hardware - Others
Burley flueless gas stove
No solution but we have had the same problem from first installation of the stove. Burley less than helpful, now preparing to go via Trading Standards/small claims route.Expensive fire, poor after sales and quality.
Sep 15, 2013 | LG Kitchen Ranges
Premier free-standing gas range, 20", how much clearance from wall?
If you are seeing the bubbled paint on wall when you open the oven door, it is more than likely heat loss past the door gaskets. They are easy to install clip on gaskets
Feb 05, 2013 | Premier Kitchen Ranges
Why is our ETS heater streaking the walls and ceiling black?
Electric heaters should not give off anything to make the paint go black , paint will change colour from the heat over time . I would say make sure there is nothing behind the heaters causing this to go black .
Ask where you buy your paint they can advise on paint that will not change with the heat .
Mar 17, 2012 | Heating & Cooling
Im have a flueless gas fire which was installed before Christmas however I am reluctant to use it as the wall it is attached to becomes unbearably hot and has cracked my plaster wall. Also there seems to...
Something doesn't seem right to me, I've installed enough of them to know you shouldn't be burning the wall...the smell could be the ceramic logs, if it has them, or the ceramic blocks, but only the first few times, after that, I'd be suspecting the wall, not good. Call the installer...
Feb 27, 2010 | Heating & Cooling
Smeg retro style fridge, 2 years old. Water keeps building up in the bottom of the fridge. Tried adjusting temperature, nothing seems to make a difference.
at bottom of back wall inside fridge, there is a gulley with a drain hole in the middle and this is blocked. push something flexible down the hole till water flows away freely
Nov 05, 2008 | Refrigerators
Open Questions:
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
