Question about Zefal Bicycle Air 1 Floor Pump
I can't get my pump to pump air in my daughters tire. This is my first time using a pump where I have to set the pressure. What do I set the pressure to in order for it to pump the air in the tire?
    Problem Solver:
  • 11 Answers
You don't have to "set the pressure", that knob is just for your own reference.
Most problems of this sort are due to not getting a good seal with the tire nozzle. Here are some steps to help you along.
1. put the bike on a flat surface
2. spin the wheel so the nozzle is facing upward
3. put the pump end on the nozzle with the lever down (this is a common mistake as older pumps had to start with the lever up)
4. Push the end down on the nozzle and pull the lever up
5. If you hear air escaping, then hold the pump end on the nozzle for the first few pumps.
6. pump it up till its a bit hard but be careful you can pop it.
check out the video for a but more info and good luck!
Posted on May 04, 2011
2008 Lexus ES 350 low tire pressure warning light
1) go to a gas station with an air pump. Unless u have an inflator/compressor at home with the tireattachment
2) lower all 5 air pressures including the spare in the trunk to maybe about 28 PSI
3) now reset the TPMS (on the 07 there is a button to "calibrate" the TPMS and it is located under the dash. I presume it is the same on the 08.)
4) now bring the pressue back up to 30/32 or whatever it says on the door area
If this doesn't work, it is possible u have a defective TPMS
but my bet right now would be that someone "calibrated" the TPMS to the current tire pressure so the light is constantly on. It happened to me before when my daughter was messing around and hit that button.
Oct 03, 2016 | 2008 Lexus ES 350
When a tap is turned on the pump keeps clicking on and off instedy of steady
It sounds like your water holding tank needs air. You could just add some air and see if that helps. The proper way is to shut the power off going to the pump. Next open up a spigot until there is no water coming out. Then close the spigot. Now check the air pressure in the tank. Water tanks come with a tire valve installed, so all you need is a tire pressure gauge. There should be a label on the tank that will tell you how much the air pressure should be. As I recall, it should be around 38 lbs. But, that would depend on the pressure switch that is installed on your pump. A common one used is 40/60. To add air use an air compressor with a tire chuck. You could also use a bicycle pump. When the tank is at the correct pressure turn the power, going to the pump, back on. That's it. Additional info: Your tank should have an air valve located somewhere on the tank, usually on top. You add air the same way you add air to a tire. Through the air valve. If there is no valve, consider replacing the tank with a tank that does have a valve.
Jun 24, 2015 | Plumbing
Problem with pump?
The pump pressure switch should be checked to see what the ON-OFF pressure is set at. Typically the pressure switch is set for 20-40 psi, or 30-50 psi. The pressure tank should be purged as well. With the pump OFF, and the tank drained of water, the air valve on the tank should read approximately 2 psi below the "on pressure". So if the system operates at 20-40, the tank should be pre-charged to 18 psi. If water escapes from the air valve, the internal bladder in the tank is ruptured, and the tank needs to be replaced. A tire air gauge is used to measure the pressure in the tank after the water is emptied from the tank.. A tire air pump or a compressor is used to charge the tank. if a compressor is used, be careful not to over-inflate the tank, as this may cuase the bladder to rupture.
Apr 14, 2014 | Utilitech Plumbing
Pump not holding presure
If you have a bladder - type water pressure tank, it probably needs to be purged of air and then pre-charged to 18 psi. There may be directions on the side of the tank. Turn the water Pump off. Drain the tank of water. Check the pressure of the tank at the air valve on top of the tank. The pre-charged pressure of the bladder is set to 2 psi below the lower pressure set by the pressure switch, so in your case, the low end pressure is 20 psi. Therefore, the pre-charge pressure of the tank is 18 psi. If you set the pressure switch to operate at 30 -50 psi, then the pre-charge pressure would be 28psi., etc. Once the pre-charge pressure is set, turn the pump back on. ( don't forget to close the drain valve). The system should cycle normally. A tire gauge works to check the tank pressure. An air compressor may be used to charge the tank, but be careful not to over- inflate the bladder. A tire air pump may also be used. Hope this helps....
Apr 06, 2014 | Utilitech Plumbing
Pressure switch cycles on off
Check your pressure tank, sounds like bladder has a leak. Unscrew cap on valve on pressure tank (looks like valve on car tire where you add air to tire) turn cap upside down and use, or small screwdriver to depress valve, if water comes out bladder has burst and replace pressure tank. If not then check bladder pressure with tire gauge. Correct settings are clearly posted on pump. Then add air to pressure tank or remove air to correct pressure. Use a accurate pressure gauge.
Jan 29, 2014 | Plumbing
How do I reset the TPMS warning light on my 2007 Nissan Pathfinder ? I have inflated a low air pressured tire too the proper inflation pressure, but the warning light remains on. Can anyone help me with...
My daughter has a 2006 Murano, and has had the same problems.
Replacement Tire Pressure sensors are available from e-bay online, but when the first one of hers quit, I found out from the dealer that the computer loses track and must be reset. I would not replace any wheel sensors just yet.
Where we live, the Nissan dealer wants about $150 to reset the computer and turn off the "flat tire" light.
Recently, a local tire store has offered to do this for free.
I took my daughter's car in to have the computer reset.
The store manager says they cannot reset Nissans or Toyotas, only the dealer can.
So, my daughter is living with the "flat tire" light.
Jan 14, 2013 | 2007 Nissan Pathfinder 4.0
Do you have step by step instructions on how to use floor pump air 2?
Place the end of the air hose nozzle from the pump on the tire valve.
Flip the lever on the side of the air nozzle straight up to lock the nozzle to the tire valve.
Hold the cylinder in one hand. Grab the end of the pump by its handle.
If the handle flips up, flip it up and turn it sideways and let the handle slip into your palm.
The stem of the handle should be extended between your middle finger and your ring finger.
Pull the handle straight out.
You will hear a slight hiss as the air is pulled into the bottom cylinder
and air is expelled out down the hose at the same time.
Push down on the handle to expel the air into the hose from the bottom of the cylinder.
Continue pushing and pulling up on the handle as you hold the pump in your hands until the tire is firm to the touch.
Remove the air nozzle from the tire valve.
Place a tire-pressure gauge on the valve to check the pressure.
Continue pumping and checking the tire to inflate it to the recommended pressure that is marked on the side of the tire.
May 14, 2011 | Zefal Cycling
Tire pressure monitor error on cadillace escalade 2005. Cannot reset as instructions. What could be wrong.
You may have a bad wheel sensor, try it one more time, scroll to tire pressure setting then go to driverside front wheel and you let air out until horn chrips then move to right front tire and let air out until horn chrips then go to rt rear and let air out until horn chrips then left rear and let the air out until horn chirps, then turn off ignition and set all four tire pressures, then start and tire a few feet they should all be set, take note when horn chrips telling you that its in tire pressure setting mode you have limited time so make sure you have all the valve caps off and something to release air, when letting the air out it may take up to a min to get the horn to sound for confirmation or the tire, but once the last tire is confirmed then key is turn off and you have time to set all tire but try to do it within 10 min, hope this helps,
Nov 08, 2010 | 2005 Cadillac Escalade
Unable to figure out how to inflate a bike tire
Could this help?
  1. Have the lever on the pump head pushed down, flat against the pump head.
  2. Push the pump head FIRMLY onto the tire valve.
  3. While still pushing firmly, flip the pump head lever up to lock the pump head onto the tire valve.
  4. Inflate to desired pressure.
  5. When finished, push the pump head lever back down and pull the pump head off the tire valve.
(Once you hook the pump up to your tire and start pumping, the back pressure will switch the flow to the bike valve output.)
Apr 07, 2009 | Cycling
Mounting Tubeless tire on Rim of riding lawn mower
With the mower jacked up place a belt or rope around the center of the tire all away around and draw it tight. Apply pressure and when the tire starts to fill you can release the belt. Apply pressure until you hear the bead pop, indicating that it has a bead lock to the rim. Let the air out to the right pressure, check all tire pressures and set the deck to level. Go mow your lawn.
Jul 16, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Zefal Bicycle Air 1 Floor Pump Logo
718 people viewed this question
Top Zefal Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Zefal Cycling Expert? Answer questions, earn points and help others
