Question about Nexus The Jupiter Incident for Windows
I previous had nexus Jupitor incident but something happened to it and i had to uninstall it. When i try to install it back on it takes me to the modify/repair/remove screen, however when i try to do any of the above options it saids that their isnt enough space on my K: to complete the process. Ive plugged in all my external harddrives and i have no K:. Ive also gone through the registy to make sure that there is no trace of nexus anywhere on my computer so i could just install it like im install a brand new game but to no avail. Someone please help
Why will my LG Nexus 4 Smartphone not power on when fully charged?
Plz contact the nexus mobile service , because it is due to some hardware problem
Jul 26, 2014 | LG E960 Nexus 4 Black 16 GB Smartphone -...
My laptop is saying that the Nexus is unknown and will not connect.
I don't have a nexus but have had a similar problem with a cellphone. If you go into the settings you should look for a link to change the connection type, i.e. some products will connect as a storage media device allowing you to browse files or as a modem to allow you to share the 3G connection or in propriety mode where it will connect as a Nexus to the bundled software.
With the Blackberry Playbook you have to install specific drivers stored on the Playbook before it is even recognised correctly. Please check if you have installed the drivers correctly. They might come on a CD boxed with the Nexus or if you connect the Nexus you'll find a new drive and it will contain an exe to install drivers so the PC can recognise it. The later was the case with the Playbook. Alternatively try downloading new drivers from the support page for your particular Nexus model. Web downloads are almost always the latest version of drivers and the one shipped with your Nexus may not be properly compatible or flawed. Hope this helps.
Nov 15, 2013 | ASUS Google Nexus 7 Tablet
I tried to reset my bb by removing my battery and putting it back in, but it wont boot up, just flashes a red light. have tried to connect to pc, wont recognize. have tried resetting several times...
Hopefully you have sync'd the BB before this happened.
1) uninstalled DM4.7 (this also fixed the annoying virtual serial port issue)
2) deleted/uninstall the BB4.2 and BB4.5 versions previously installed onto the computer
3) downloaded and installed DM4.5,
4) installed BB4.5
5) removed the vendor.xml file
6) with the phone disconnected, put in the battery for a split second until the solid red LED shows, then connect the mini-usb cable to the phone and at the same time take the battery back out (this seemed to be the only way to make the PC 'detect' the phone)
7) run Application Loader, which detected my BB4.5, and updated the phone's OS/software/apps
8) near the end ,when the app loader says something like "connecting to phone" or something like that, put the battery -back- into the phone
9) this seemed to initiate the installation of the phone's core modules, a 10 minute process or so
10) after that you get the rotating hourglass thing on the phone's screen, and after waiting about 20 minutes or so, VOILA!!
Nov 26, 2010 | RIM BlackBerry Pearl 8100
I need the key code for the game cald nexus
download it from the internet type on google "nexus the jupiter incident serial" and look for serials hope it helps
Apr 10, 2009 | Nexus The Jupiter Incident for Windows
Uninstalled blue ooth by accident!
You can try to let your computer detect it as "new". If you start up your computer, go into the control panel and choose the "Add New Hardware" and let the computer try to detect the bluetooth by itself. That's the easiest way. If it doesn't detect it, you can do it manually in the "Add New Hardware" also.
Feb 27, 2009 | Computers & Internet
Loss of internet, blue tooth light wont turn back on
Here are some things to try. I would remove the bluetooth adapter. Is it built in? If so, you will not be able to do this. If it is an adapter take it out and try putting it back in. Did you install new software? Do you have anti-virus? I would recommend that you do a system restore to the point of when it happened. The system restore will restore the settings previous to the incident. Now the next thing is to do a right click of the system and go into properties. Depending if you have Vista or XP the Device Manager will be in different spots. Look in the Device Manager and uninstall the BlueTooth. Reinstall the device. If the BlueTooth is built in then you will probably have to contact tech support at Gateway.
Let me know if you have any other question.
Dec 31, 2008 | Gateway Computers & Internet
Rough start occassionally
first i'd try changing the air filter, if that doesn't work, try the fuel filter
Nov 28, 2008 | 1996 Pontiac Sunfire
Installing VMware server on Ubuntu 8.04
try to locate vmware if you really have vmware installed via
locate vmware
if vmware was found try to find the uninstaller via
then execute the ./
Aug 27, 2008 | Canonical Ltd. Ubuntu
Problem installing office 2007.
go to website download uninstaller and completely remove previous version office. Using this application every entry related to previous version will be removed
Dec 18, 2007 | Microsoft Office Professional 2007 Full...
Nexus The Jupiter Incident for Windows Logo
Top Nexus Video Game Consoles & Games Experts
James Wishart
Are you a Nexus Video Game Console and Game Expert? Answer questions, earn points and help others
