Question about Mantis Garden
I have had my mantis for five years. It has always been hard to start. From the very beginning I had to move the choke in and out after it started to keep it from dying after it started. Each year it has gotten harder and harder to start. This year it will run a split second and die. I can pull the choke out and pull the cord one time, then push the choke half way back in and pull the cord and it will start momentarily, then die. I have gone through this process until I am exhausted. In the past, after doing this for awhile, it would stay running a little longer each time until it warmed up. What do I do to keep it running? Thanks in advance for any assistance you can give me. J. May
  • 2,510 Answers
I feel it might be time to overhaul the carburetter. Clean out all the passages and jets, especially the little screen that is pressed into a hole under the one diaphragm. Clean out the recess for the needle and seat and replace all the gaskets, the valve plate and the primer bulb. Also check the fuel tubes and the filter at the end of the intake tube (if it has one). If there is too much wear on either the choke shaft or the throttle shaft, it may just pay you to replace the carb completely.
Posted on Mar 17, 2011
Starting manual for mantis
all of the mantis tiller manuals can be found here:
http://mantis.com/mantis-owners-manuals.asp
just pick out the appropriate one and away you go.
as far as starting it goes, make sure the switch is set to "I" and not "O" (top handle.) be sure you have gas in it, pull out the choke knob (front of the tiller) and depress the bubble once. pull the engine cord until the machine tries to start, then push in the choke and pull again - the engine should start within a couple of pulls. let it warm up before you try to do any tilling, and you're good to go!
Sep 12, 2012 | Mantis Gas Mini Tillercultivator 2cycle...
Cannot get the brushcutter started, it has spark but doesn't want to go. Have forgotten the method of starting, eg. 10 prime pumps, five pulls with full choke but turned off, then half choke turn on...
Normal starting practice is always done with the ignition on, primer as many times as it takes to 3/4 fill the bulb, move choke to full closed, crank engine until it fires once, move choke to half if there is a half position, crank engine until it starts and runs, move choke to full off.
Aug 24, 2011 | Garden
Mantis will only run when the choke is on. If I try to push the choke in it dies.
Having owned a Mantis for many years it sounds like your air/fuel mixture may be to lean when you push the choke in. First check the simple stuff. Make sure you are using fresh fuel with the proper 2-cycle oil mixture. Check or replace the fuel and air filters. Replace the spark plug annually. These are the routine maintenance procedures found in your owner's manual. If none of this solves your problem either the carb fuel mix adjustment screws are not set properly or a carb rebuild kit is needed. The proper setting for the mixture screws should be detailed in your manual. Removing the carb and replacing the needle valves, gasket and other items takes a little more expertise. Before jumping in to this and assuming all other maintenance has been performed press the fuel primer bulb several times before trying to start it. You should feel resistance after 3-4 pushes. If you don't feel any resistnace the carb is not being primed and the bulb needs replacement (you may notice a small fuel leak if this is the case). If you can get it primed, pull the choke out, start and let it run a minute or so. Then make small, gradual changes by turning the fuel mix screws (not the idle adjustment) as noted in your manual. Try to push the choke in half way or as far as you can without killing the engine. If may run a little rough but continue tweaking the screws until it smooths out a little. Gradually continue pushing the choke in and turning the adjustment screws as needed to keep it from stalling. This is best done with the tines supported off the ground during adjustments. Just make sure to protect yourself and others from coming in to contact with them. When set correctly you should be able to achieve full throttle with the choke fully closed. A little time and patience should get you up and going again. Of course you can always contanct Mantis at www.mantis.com or call them for troubleshooting assistance. Hope this helps.
May 25, 2011 | Mantis 2-Cycle Tiller
Can not find my manual for the mantis tiller..forgot hot to start it up for the first time
You should be able to go to the Mantis web site and download the owners manual. To start, make sure the switch in turned on, push the fuel primer bulb several times (until you feel resistance), pull the choke out all the way and pull the starter rope until it fires. Then, push the choke half way in and it should start. Let it run a 30 seconds to 1 minute and then push the choke all the way in. Be sure you are using the currect fuel/oil mixture with fresh gas and oil. If you have not done so already clean the air filter and replace the spark plug at the recommended interval.
May 23, 2011 | Mantis 2-Cycle Tiller
Will only start and run in choked position, when throttle applied chokes out. If started with out choke and throttle position in low speed will start and run for 10 sec then like it runs out of gas.
i have your solution guaranteed, I fixed mine yesturday remove H L screw plastic caps and on high 11 threads exposed and on the low side 8 threads exposed. removing the plastic caps allows u further adjusting these wear out or move soo just take them things off and you will be rolling
Apr 18, 2011 | Mantis 2-Cycle Tiller
Mantis starts and runs but lacks power and is slow to rev up
Check the air filter and ensure it is clean, replace if necessary.Foam filters can be washed in hot water and detergent, paper filters need to be replaced.
Ensure the throttle cable moves freely and the choke is turned off after starting.
Mar 08, 2011 | Mantis 2-Cycle Tiller
I forgot how to start my mantis.
close the choke , pump primer bumb 3 or 4 times pull rope with the switch turned off then turn it on and pull rope again.
Apr 25, 2010 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Older Mantis 2 cycle must be choked to run
look on the side of the carb for 2 small adjusting screws they will be almost touching( they will have springs on the threaded part of the scews) the heads will be small 3/16 " open these counterclockwise, this allows more fuel in. The one closest to the engine is for the idle mixture the other is for high speed , tilling speed. 1/2 to 1 turn may help, good luck . try PER small engine tecnical forum online
May 20, 2009 | Mantis 2-Cycle Tiller
Mantis to stroke start not very easy once it starts use for five minutes then it stops and doesn't start again I bought this from the ebay in February 2009 and I paid under £175 when I bought it the person...
either the choke is still on
or
the air filter is so dirty that it is acting like a choke
either way, replace your spark plug and air filter
if your air filter is foam, you can clean it in gasoline, just be sure to air dry it before refitting it and tring to run the mantis
the carburator can be dirty and or having the screws out of adjustment.
thy the spark plug and airfilter first
Apr 01, 2009 | Mantis Electric Mini Tiller/Cultivator
Garden Logo
295 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
