Question about Freezers
Engine runs for a minute or so then shuts down with a fault code of A41 engine shut down. Any idea on a Carrier Vector 1800 Cheers if you can help?
My Woods upright freezer MU07W running great for 9 years. Will it continue to run if I decide to place it outside on the balcony where temperature goes down to 20 below F or to max of 90 F plus?
Not the best idea. We had one in our garage where it got cold but not that awful cold. Not a good idea unless you want to take a chance.If the unit shuts down for a long time because of the cold the system could freeze or seize up.
Feb 05, 2017 | Woods Upright Freezer MU07W
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Why doesNuwave oven shut down after one minute
How can i call customer service
chef@nuwavenow.com.If you have any questions please contact NuWave customer service at 877-689-2838 M-F 8am to 4:30pm CST. A representative will happy to assist you.
If you prefer to contact the company by
Aug 03, 2014 | Hearthware Nu-wave Pro Digital Black Oven
Chest freezer suddenly stops working then will start again later
This is normal if your freezer is in good working condition. If your compressor runs constantly then there is a problem. Once the unit reaches the set temperature the compressor shuts down. The set temperature should be between -2 & +2 degree F. The set temperature also depends on how full the freezer is. There will be a time when the freezer like refrigerators will shut down. This is relative to the term, "Frost Free". The unit will shut down for about 10 minutes. This occurs ever 8-10 hours. The heater turns on to defrost your freezer coil. It sounds like you are in good shape.
Apr 18, 2014 | Westinghouse Freezers
Need to adjust my temperature differential on my carrier pulse freezer mod#ULG50BC-5
Is this a digital or standard model . That helps me in figuring this out.
Mar 01, 2013 | Carrier Freezers
Unit shutting down and temp riseing to 100 degree
If the start relay and cap are ok then I'd say it's time for a new compressor. Have you tried running the compressor directly with a direct start circuit? cheers
May 13, 2009 | Coldtech 40 cu. ft. / 1133 liter...
Beeping Ice Machine
the beeping is a fault code i need to know how many beeps it does before it starts over Also you can shut down the pwr this will reset it but if you dont fix the fault it will return
Jul 06, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Feb 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Freezers Logo
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
