Question about Braun 8585 Electric Shaver
I am trying to remove the pivoting head from my Braun 8585 ... removed screen and cutters and the two screws under the cutters but cannot see what else to do to get the head removed
  • Braun Master
  • 1,623 Answers
The swivel frame can not alone be removed from the shaver. It is part of a component called a 'drive unit' which icludes the motor. You will find a disassembly video at shaveroutlet.com. See link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Posted on Mar 18, 2011
Braun activator 8585 change the foil
braun series 5 combi 51S outer foil and cutter replacement pack (Formerly 8000 360 Complete Or Activator) for men electric shaver braun 8585 replacement parts.
Jul 30, 2013 | Braun 8585 Electric Shaver
I can't figure out what is wrong. When I try to use the razor the cutter seems frozen and doesnt move side to side. When I take off the foil I see that the cutter seems to move perfectly fine. I then...
If you are having the same problem with both your old and new foils and cutters it sounds like there is a problem with the oscillator in the swivel frame. Sometimes the plastic oscillator inside will partially break and it can not vibrate under the load of the foil and cutters.
This swivel frame is part of the 'drive unit' and can be found available at shaveroutlet.com. See link below for item and scroll down the item page for installation video
Aug 16, 2011 | Braun 8585 Electric Shaver
I've connected it to 115v with cable from old Braun and probably burned out fuse or rectifier. How I could take apart the shaver?
To open the shaver body on model 8585, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
You will probably need to replace the circuit board you will find a replacement circuit board for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-activator-circuit-board-with-batteries-select-models-p-363.html
Jul 31, 2010 | Braun 8585 Electric Shaver
How do I open a Braun 8585 shaver to replace the battery?
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
Jul 13, 2010 | Braun 8585 Electric Shaver
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
I have dropped my braun 8585 although in a bag. It is charged but just no longer works. I thought that taking the head off might reveal a broken connection but could not find a way further than removing...
Replacement parts can be found at shaveroutlet.com
Jun 27, 2010 | Braun 8585 Electric Shaver
Braun Drive Unit 7030244
To open the shaver, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
You will find a replacement drive unit for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Apr 07, 2010 | Braun 8585 Electric Shaver
Problem with shaver
are you talking about springs under the center cutter bar between the foils? If so, you will need a new foil and cutter set. It is available at shaveroutlet.com with link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Or maybe you refer to a spring that goes to one of the clips that hold the foil assembly to the pivoting swivel frame. If so, you will need the part linked below
Jan 14, 2010 | Braun 360° Complete 8985 Electric Shaver
Braun 8585 maintenance
Look at the bottom of the shaver where the AC cord plugs in. Carefully pry the small black piece of plastic out of the base. Once you have this out, the two chrome side pieces will fall off, and you can split the shaver in half to expose its inner workings.
Sep 19, 2008 | Braun 8585 Electric Shaver
Braun 8585 Electric Shaver Logo
221 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
