Question about Vacuums
Hello! I have a problem with my Tefal Sensio scales. They are now probably around four years' old and have been in perfect working order up to now. Well, I had some problems before - the moment I'd step on them, instead of going into "calculating mode" as they usually do, they would show the number 92 straight away and then the display would change into some strange symbols (please don't laugh here :-) - my weight in kg is 55, my husband's around 80 and each of us gets 92 reading). Previously, the problem used to disappear after replacing the batteries but not this time. And unfortunately I cannot find the User Manual. Can anyone suggest what I should do now? I've heard that scales could be "recalibrated" - should I try this option? Or just lose the old scales and buy new? (losing weight is not an option :-) ) Thank you in advance!
KOakaKO
  • 135 Answers
SOURCE: Scooba 5800 Power button Red Blinking (Continued)
As for which one has the problem, I would say it has to be the battery. Rechargeable batteries of all types are known to have similar characteristics, one of which is discharging the batteries to maintain good rechargeablility. At least one person has demonstrated this for the Scooba battery in the roombareview.com forums when he brought a "dead" battery back to life. He allowed the battery to slowly and completely discharge using a 12-volt automobile bulb, followed by recharging the battery on the Scooba external charger. This procedure brought his "dead" battery back to a full charge! However, other forum members have reported that many have experienced problems with Scooba battery life, and that as a consequence of this iRobot will replace your battery if you call them and report a short-life battery problem. You can contact iRobot at (800) 727-9077 if you would like to report a battery problem and request a replacement.
Posted on Aug 11, 2007
SOURCE: McCulloch Chain Saw Manual
http://ipl.ordertree.com/ipl/327/Chainsaws_Electric.pdf
Posted on Jul 27, 2008
SOURCE: vacuum gets hot loses suction and turns off
You need to replace your silencing filter on the inside. I recommend calling Health Mor at 800-344-1840 and having their Tech. walk you through replacing that filter. It should have been replaced at about 2 years. It catches the carbon off the motor, but if dust is getting through it can clog it and cause your motor to overheat.
Good luck,
FQ Master
888-637-4692 in Iowa
Your Filter Queen Authorized Service & Supplies
Posted on Jun 16, 2009
SOURCE: Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Posted on Jul 15, 2009
  • 97 Answers
SOURCE: Electrolux 2-in-1 Pronto is losing suction. We've
yes try new battery it sound like a power problem.thanks
Posted on Nov 30, 2009
Myy wertheim steam mop is over 2 years old. Wont steam, have followed manual instructions for maintenance etc and still wont steam. Is it time to replace it.
If you live in a hard water area and haven't been using distilled or deionised water, it could be a good time to replace it due to a probable internal build up of scale. If it hasn't already caused trouble it is almost inevitable soon.
If you have been using soft water and/or descaling regularly the steamer should still be relatively clean internally and it would be worth finding a competent person to check the circuit, cable, switch, but not at full retail prices or if it must be replaced it will be wasted money. Find a friend or neighbour who will do it for a beer...
Jun 01, 2017 | Vacuums
Roomba spins around in 1 place. it then stops and beeps 9 times. it seems perfectly clean sensors are cleaned etc.
Your bump sensors are malfunctioning. The best thing to do is order a repair kit.. I ordered mine from EESolutions.ca and it worked great.
Dec 01, 2010 | iRobot Roomba 560 Robotic Vacuum
My steam cleaner will not get hot enough any more. It is only a year old.
probable scale problem in boiler. Try using coffee machine de-scaler add to steamer heat and rinse. De-scaler available from most stores selling automatic coffee machines. Or it may be an element failure.
Sep 13, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Heating up but not producing steam. Tank may be furred up as limescale deposits in water when tank emptied.
OK. This is an actual guaranteed solution to the Shark "No Steam" problem. The problem is well documented as hard water clogs the steam mops head. And using distilled water should prevent problem (not confirmed). But now that you have the problem, how do you unclog?
First off, Ive had two now. And my solution probably invalidates 1 year warranty, but I'm not interested in going through all the rigamarole of taking my mop back to the store. Maybe yours has expired or you want solution now like me.
This requires a drill. If you've tried the white vinegar route like me and it hasn't worked, and the toothpick, now it's time to get serious.
Remove the four screws. Then slide connection back and remove final two screws. Try blowing thru the small round hole at the end of the connector. If you can't blow through it, the smallest choke point near the hole is your problem.
Using the smallest drill bit in the standard drill set (not sure the size but it fits easily in the hole with room to spare) drill gently into the hole until it breaks thru the first resistance. Now blow through the hole. It should blow through easily now. Run some white vinegar thru to loosen up and remove other hard water deposits if you like.
Replace nozel. Replace two screws, Replace 4 screws. Done.
Use only bottled distilled water from now on would probably be a good idea.
In my opinion the problem is a design flaw built in by the Shark people. Appropriate name. Its called planned obsolescence. :( It breaks, you buy a new mop head (or entire mop if you can't find their part's website.)
Sep 13, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
H3000 doesn't start.
No fuses. The only thing in the circuit is the switch, so it's probably that. Good-luck.
Kirk Thompson
San Juan,PR
Oct 28, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Model number U5763900 Serial Number 090400013588 Handle broke off just above the four screws that attach it ti the boby of the vac. Hoover does not list parts for models that are more than two years old....
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=658103
Generic problem for all Vacuums
Posted by rlholif on Jun 09, 2008
Model number U5763-900 Serial Number 090400013588
Handle broke off just above the four screws that attach it to the body of the vac. Hoover does not list parts for models that are more than two years old. The vac operates perfectly but without a handle my wife cannot use it, where can I find a part replacement. Easy to remove four screws and replace. Don’t want to drive 100 or more miles to find an authorized repair shop. Oh yes, this is a Hoover Preferred Wind Tunnel Bagless
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You have all the information needed but I would contact your local vacuum cleaner dealer and they may have a good used one or they may stock a new handle for your you or they can ship you one If you live too far from a factory authorized dealer. The vac shop that I worked in always had good used parts for ½ the price and it worked just fine – the only difference was the color and for the handle that would not make a difference in the performance and your wife could use the vacuum again. Also Hoover can ship the part to you providing they have it in stock. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Vacuums
My old Tristar canister vac.
If you have a voltage meter you could see where the problem lies. All TriStar parts including the motors, both the nozzle head motor and the actual vacuum motor are purchaseable online through www.totalvac.com
I have ordered parts through them and everything arrives no problem and they are priced nicely by the way.
Feb 11, 2008 | Vacuums
Aerus electrolux CB 2000
I e-mailed Aerus about my old Model CB unit, (around 40 years old, looks like a chrome and red shop vac) and, unfortunately, they no longer make parts for it and I decided to retrofit my old Shop Vac 5-8 Gallon bags to it and they seem to work. However, probably better to find a ring and gasket from a vacuum place that was known to sell them or ask the nearest vac stores, like the other fellow said to get some information. The old canvas filters I would think were more or less motor protection barriers just in case something gets sucked into the intake. By the way, I have seen the occasional CB units on eBay and other sites, and, the 2000 looks a bit like mine only in modern plastic as opposed to metal (apparently different colours).
Jan 16, 2008 | Vacuums
Vacuums Logo
155 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
