Question about Sanyo PLC-SU50 Multimedia Projector
Sanyo plc-su50 projector - can't get it to work
We have been loand the projector and got it projector powered up and projecting a blank screen but cannot get it to play our slide show. From the manual it doesn't appear we need any form of software on the computer but it just says there is no input - don't know if we have any leads missing. All we have is the main power lead which is obvious. A lead with a white pin plug on one and and a smaller blue one on the other - only the blue end is the right size for the ports on the back of the computer so presumably this is the only way it can go. The only other lead is a usb lead into both the back of the projector and pc. We were told you just load your file and press control and f4 or f5 and it should projector, but doesn't. Help!
  • 10,594 Answers
Please select correct input in menu of projector, that is Computer/ PC, like that...
Posted on Aug 02, 2008
How to check for lamp life
In menu you must find the "life time" for your lamp
Mar 19, 2014 | Sanyo Plc-su50s Pro-x Multiverse Lcd...
Our projector keeps turning itself off!!
Please check that the plug is tight to the outlet, the fan is working, there is no clogging of the filter as the reduced cooling will result in the temperature rising thereby the temperature sensor will cut off the lamp to save from failure.
finally if the lamp has worked many hours it can be weak and so heats up more. If so the lamp must be changed. try to swap and confirm. Use an extra fan to check with the cooling.
Apr 11, 2011 | Sanyo PLC-SU50 Multimedia Projector
How to fix shadow (stain) projected onto screen by projector Sanyo PLC-SW30
This could be showing the signs of the lamp needing replacement. if not dust has accumulated (clean filters) onto the mirrors in the projector.
May 15, 2010 | Sanyo PLC-SW30 Multimedia Projector
Sanyo lcd projector has horizontal scrolling lines in its picture. Is this different than a lamp problem? Electrical? All else works fine. Thank you. Sanyo PLC-5600n lcd video projector. Not a tv.
This is caused by the processor and not by the lamp. As you might know, these projectors display colors by blanking out the light with lcd pixels. Most folks don't know that any display devices such as displays on cameras, laptop displays, etc. use an amazing amount of original technology that powered CRT TVs. (Yes, even vertical hold, although done electronically today, is there.) You'll just have to send this one in for service.
Feb 26, 2010 | Sanyo Televison & Video
Can not make picture bigger on my Sanyo PLC-SW20 projector
depending on the size of the surface you are projecting on, and what the zoom capacity of your lens is, you probably only have one choice available to you, and that is to move your projector farther away from what you are trying to project onto.....
hope this helps!
Jan 10, 2009 | Sanyo PLC-SW30 Multimedia Projector
Yellow band on the edge of screen
Hi chucri
This is most definitely not a lamp problem.
If a yellow colour in either stripes or blotches occur it is a blue LCD polarizer that needs replacement.
May 16, 2008 | Sanyo PLC-SP20N Multimedia Projector
Sanyo Pro Xtrax PLC-XU50
Hi there
If you have the know how open up the machine and replace the fuse on the Powersupply board ( where the AC socket sits in )
If this still occurs , I'm afraid you will have to replace the Powersupply board.
Apr 09, 2008 | Sanyo PLC-SU50 Multimedia Projector
Projectors screen turns yellow,on and off,after awhile has been looking white
You are describing Color Decay. Welcome to the world of LCD projectors. The blue device is the first to go, thus the yellow fringe. You must have about 3-4000 hours on the projector. Replace the product with a dlp product and it will last a lifetime, or until you want something with newer features.
Mar 06, 2008 | Sanyo PLC-SU50 Multimedia Projector
Sanyo PLC-SU50 Multimedia Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
