I have an ABIT computer i plug my headset in and the mic works but the speakers don't ive checked an the hardare says the speakers do work but i cant hear anything. by the way its not sound turned down or muted and my drivers all work and i have them all. its plugged into the right port i checked its run by a program called realtek. HELP!!
  • 1 more comment
  • kofly Aug 02, 2008
    well that doesnt help at all because if you actually read what i wrote ive done all this and it doesnt work
  • kofly Aug 03, 2008
    um the last thing to do with the bios might be what i need. no i don't know how to do it, and no i dont have a manual. it is an ABIT AV8 - V motherboad. all that other stuff i have checked aready prior to sending the first email but non the less people would find that very helpfull thanks for going to the truble for me. :)
    sory no its an ABIT AG8 - V motherboard.
  • 659 Answers
Make sure when you click on the speaker in the bottom right hand corner that your wav volume is also turned up or nothing will come out as well. and always plug speakers ect into green plugins on computers and speakers.
Posted on Aug 02, 2008
  • Wesley Gardner
    Wesley Gardner Aug 02, 2008
    well you can try this
    you can goto the speaker in the bottom right corner and click on adjust audio properties--->in the general tabe make sure nothing is muted in there and then go to the speaker volume on the bottom left and turn them up.----->next click on the audio tab--->make sure that sound playback is on the reltek ac97 audio
    Are your volume settings adjusted to an audible level?
    Your volume might be set too low, or audio might be muted.
    To check your volume settings
    1. Open Volume Control.
    2. Make sure that Mute all is not selected, and adjust the volume and balance controls to the levels you prefer.
    3. The controls in Volume Control are different for different sound devices. If any Mute check boxes except microphone input are checked, this might be the cause of your problem. Consult your sound device documentation or contact the manufacturer for more information.
    Note
    • To open Volume Control from the Start, click Start, point to All Programs, point to Accessories, point to Entertainment, and then click Volume Control.
    Does sound come from your speakers after you adjust your volume settings?
    Are your speakers connected correctly?
    If your speakers have cable, check the following:
    • Is your power cord plugged into a working outlet?
    • Is your sound cable plugged into the appropriate jack on your sound device or computer?
    • Are your speakers connected to each other?
    • Are your speakers turned on and is the speaker volume control adjusted to an audible level?
    Different speaker sets have different cable configurations. Consult your speaker documentation to be sure of the correct configuration.
    Can you hear sounds after you connect your speakers?
    1. Open Device Manager.
    2. Double-click Sound, video and game controllers, right-click your sound device, and then click Properties.
      If you do not know the name of your sound device, consult the documentation that came with it.
    3. Under Device usage, make sure that Use this device (enable) is selected.
    4. Click OK.
    5. Restart your computer if you are prompted to do so.
    Note
    • To open Device Manager, click Start, click Control Panel, click Performance and Maintenance, and then click System. In the System Properties dialog box, click the Hardware tab, and then click Device Manager.
    1. Open Sounds and Audio Devices Properties in Control Panel.
    2. On the Audio tab, click your sound device in the Default device lists under both Sound Playback and Sound Recording
    2. Double-click Sound, video, and game controllers.
    3. Double-click your sound device.
    4. Click the Properties tab, and then double-click Audio Devices.
    5. Click your sound device, and then click Properties.
    6. Click Use audio features on this device.
    7. Click OK until you return to Device Manager.
    8. Restart your computer.
    To check for hardware conflicts and devices that are turned off
    2. Double-click Sound, video and game controllers.
    3. Look for an exclamation point (!) in a yellow circle next to your sound device, or a red 'X'.
      • An exclamation point in a yellow circle indicates a hardware conflict. To troubleshoot this problem, go to the Hardware troubleshooter and click I need to resolve a hardware conflict on my computer, or contact your computer manufacturer for assistance.
        Important
        • If you go to the Hardware troubleshooter, you will leave the Sound troubleshooter.
      • A red "X" indicates that a device is turned off. Try turning the device on.
        To turn on a device
        1. In Device Manager, right-click the device marked with a red "X," and then click Properties.
        2. Under Device usage, select Use this device (enable) and click OK.
        3. Restart your computer.
        If turning a device on does not solve the problem, contact the device manufacturer for further instructions.
    If your computer has a motherboard sound device and not an expansion sound card, make sure your sound device is turned on in your BIOS
    if you are unsure of how to do this refer to your user manual for the abit motherboard or list the model of your computer here and I will try to locate the information for you.
  • Wesley Gardner
    Wesley Gardner Aug 04, 2008
    hey there not a problem anything to help get things going.
    click here for the manual for your motherboard and from there you can access the bios and check the settings with in that.
My headset is not wireless. the built-in mic isnt working
Did you check it is inserted in the Mic socket and not Auxillary Inout which is the other socket on the back of your computer?
Also go to Control Panel/Sound and check that the settings don't have the microphone Muted. You can sometimes get to this location quicker if you have the speaker icon down on the right side of the screen by the clock. Just double click it.
Dec 15, 2015 | Radio Communications
Cant get the mic to work
Have you set the mic you wish to use with your webcam as Default ?
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
Dec 21, 2010 | Gear Head WC330I Webcam
Cant adjust microphone
Make sure your webcam mic is set as default
XP
VISTA
TEST SPEAKERS
Restart computer
Plug the webcam and launch the Logitech dashboard ( toolbar )
Open Settings menu ( 2 gear wheel pic )
Adjust mic to suit
Sep 05, 2010 | Logitech Webcam
Webcam headset
Not sure this webcam includes a headset - check your speaker / audio settings
Vista
If you have an older OS - you may have to access your hardare from the Control Panel
TEST SPEAKERS
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Restart computer
CONFIGURE TO MESSENGER
Dec 09, 2009 | Logitech Quickcam USB Zoom Webcam
Headset Microphone doesn't work
Plugged in? Is it a stereo plug? does your computer allow speaker and mic on the same wire? Does the outlet say Mic or Headset of Both? Had it worked in the past.
Some computers have a place for a mic - some for headset - some might have both. On a desktop, I would expect to find separate connections. Laptop, Id have to look.
A 'stereo' plug will have a tip, ring and barrel connection.
A 'mono' plug will have a tip and barrel connection only.
A stereo plug would allow a mic and head phone connection ujsing a 'common' for the return.
A mono plug would allow either a mic or a headset, not both.
If you could peer into the jack inside your computer, you could tell if it privides for three wire (stereo) or two wire (mono) operation.
I hope this helps ... If I missed your question, please reask.
We are "paid" here by positive comments where we earn "bragging rights" If you are satisfied, please post positive comments
thanks
a
Oct 12, 2009 | Computers & Internet
Mic and headset not recognized
you haven't mentioned it that i can see but when you have the green plug into the green can you hear sound ?... if so look for the speaker icon on the lower right of your screen. open that to volume control.... look at the mic setting... is the mute box marked ? if so uncheck it and try the mic again
Robert
Dec 17, 2008 | GE (98980) Headset
Ive just bought a headset for my laptop, but the mic doesnt work though the speakers do. My laptop is vista and it doesnt even recognise that there is a microphone plugged in. Any ideas?
please confirm first that you plug mic jack in right socket-open volume control and check mic not in -mute--and fader in up position
Jul 16, 2008 | Audio Players & Recorders
Headset Doesn't Work...
hi Ive got a logitech headset 250 but I cant use that in my laptop and why !??
pleale help me!
see yah bye for now
Nov 13, 2007 | Logitech 250 Headset
Mic doesnt work
Totally the same with me.. any soloutions anyone?
Dec 26, 2006 | Sennheiser PC130 Consumer Headset
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
