Lid or supply code on message screen, I was typing, machine shut down.
  • 3,594 Answers
You didn't give a make of model but I'll try. Check the ribbon to be sure it isn't empty, be sure the lid is fully closed and be sure the printwheel is properly installed.
DickyO
Posted on Mar 18, 2011
I have a Epic Z Model # mhwz600tw00. When I select a wash cycle and press "start" it shuts off. It will complete a "spin" cycle without any issue. I checked the supply hoses and...
Hello Jeff,
Does the machine just shut off or do ya have a error code when it shuts off?? Typically when it will not fill with water for what ever reason their is FH error code. In addation to that since the cold water was clogged,very likely what ever caused it to clog up also has clogged the filter screen on the water inlet valve where the hoses attach to,to check/clean the screen remove the hoses and usea small screwdriver to pop out the screen and check/clean it. If ya find that the screen is clean ya may very well need to replace the water valve.
Be sure to get back to me and let me know about what error codes come up and i could help ya to better narrow down the trouble with your washer.
Thanks for using Fixya,
Gene
Feb 29, 2012 | Maytag EPIC MFW9700S Front Load Washer
Very little hot water runs in tub
you either have a problem with the house water supply going to the washer and you can remove the hot water hose from the washer,first shut down the water,stick the end of the hose inside the washer and turn the water supply back on,if the water comes out normal then you have a bad water valve on the back of the washer.call your parts store and give them the full model number off of the washer,open the lid,follow it down to the bottom and right under the bottom of the lid you'll see the model number
Jan 23, 2011 | Kenmore 24032\24036 Top Load Washer
My E machines PC (5 yr old w/ XP) shuts down
I should have been glad if you count that beep for me. Every beep codes have distinct message. Anyway, may my tips shoots ur problems :
1. unplug the main power cable and remove the cpu cover.
2. check RAM sticks, power supply ports and other add on cards if properly seated.
3. And then back on.
Jul 29, 2010 | E-Machines eMachines Desktop PC
I have an error message that reads ob. I have an
OB MEANS OFF BALANCE if the motor controller detects an unrecoverable off-blance condition, the machine controller will shut down and display ob. the lid switch must be opened at least once before restarting the cycle if this condition occurs. opening the lid will allow you to view and redistribute the load. press stop/cancel to clear the display. hope this helps.
Oct 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Washer will not fill wash basket with water.
It's either a water supply issue or an electrical supply issue..
If it's a water supply issue, check the hose screens at the inlet hoses. Shut the water off to the machine, and take the hoses loose at the faucets. Take the screens that are in the hose end out and clean them, then reinstall.
If it's an electrical issue, you won't get any response from the machine when you start it.. not sure if this is your case, but the first place is to check the circuit breaker and reset if needed. Then check the lid switch operation. This switch will keep water from flowing if it's not properly operating. Sometimes the lid on a washer can get slightly bent by too much weight be placed on the machine. Open and close the lid and listen for a positive "click" from the micro switch.
Those are good things to check for a start...let us know if you still have a problem with your kenmore.
K
Jul 29, 2009 | Kenmore Washing Machines
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Philips 3258
1. With the remote control, turn on the player. Keep the tray closed.
2. Press SETUP and use the buttons LEFT or RIGHT (arrows) to go to the Preferences Page.
3. Type 138931 and a screen will appear on TV.
4. Use the buttons UP/DOWN (arrows) to change the region code to 0 (zero), then press OK.
5. Turn off the player and turn on again.
OR
open lid; slowly press 9,9,9,9, then 0. will show region 0 on screen for maybe 2 seconds , shut lid & you are done!
One of these 2 should work. If one does post back which one please.
Sep 08, 2008 | Televison & Video
Lid Display lit when starting wash cycle
LID code could mean that the door lid switch is not pressed. try to shut the door completely or the lid switch could have been broken. or the plastic that should press the lid switch could have been broken also. it is attached to the door i hope i was able to help.
Jun 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer
lid flashes when the following conditions occur:
➔ User presses START with lid open.
➔ User presses START after 2 consecutive machine cycles
without opening lid.
➔ The machine/motor control cannot detect the lid switch
opening and closing properly.
BOYNISMO@YAHOO.COM
Mar 17, 2008 | Kenmore Oasis HE 27087
Lid Error
Most systems either have a photo interrupter or a switch on the top to let the copier know its closed. Since you had it moved most likely they knocked it out of its position.Or broke the tab or plunger off.
Oct 17, 2007 | Konica Minolta DiALTA Di200 Copier
41 people viewed this question
jasbo
jasbo
