Question about Sewing Machines
While sewing an 85" border
  • 2,510 Answers
The fabric, top and bottom, are fed only by the feed dogs under the needle plate. Over such a long sew, the friction of the presser foot, minimal as it is, will ****** the feed of the upper material while the bottom layer has the positive feed from the feed dog. Also, the friction between the two layers of material will not be enough to prevent a little slippage, exaggerated over the entire length of the work piece. Hence the difference at the end of the job.
Posted on Mar 17, 2011
  • Hans Pearson
    Hans Pearson Mar 18, 2011
    Just as an afterthought, there is no shame in pinning the two layers of fabric together prior to making your run, and then pulling out the pins as you go along. This is useful for odd shape sewing as well, just remember, pins and sewing machine needles do not get on well together.
I only have a small amount of feed through the sewing claw, i mostly have to pull it through on my Toyota 2400, is this normal is is something wrong?
Unable to locate much information about your make/model machine.
If your machine has the capability of dropping the feed dogs for darning or free motion quilting, check that the feed dogs are in the up position for sewing. Also, verify that the stitch length is set to at least #2. Any shorter stitch selection will cause the machine to advance the fabric so slightly that it will nearly sew in place.
Some machines also have a pressure adjustment for the presser foot. If the fabric you are sewing is very fine, the feed dogs may have difficulty gripping the fabric to advance it through the machine. You can add body to the fabric by including a stabilizer when sewing the fabric, ie a wash-away stabilizer.
May 05, 2016 | Toyota Sewing Machines
Why do i find that when free sewing the cloth will not move freely?
If you are talking about being able to move the fabric freely with your hand, you need to drop the feed dogs and install a darning foot. The darning foot is just a smidgen shorter than the standard presser foot so it does not rest on the feed dogs or the needleplate. The extra space allows you to manipulate the fabric without feed dogs.
Jan 16, 2016 | Singer Confidence 7463 Computerized Sewing...
How do I sew the side front panel to the front panel at the bust?
this is a technique that is developed by experienced sewers
I suggest that you go to a local sewing shop where there are people who will be only too willing to help you with this problem
it is like a sewers club and it is always helpful if you want to take on more ambitious projects.
Jul 23, 2015 | Sewing Machines
How can I get my Bernina 750 to feed the top and bootom fabric pieces for quilts evenly
Try using a walking foot. The issue most quilters face when working with any sewing machine is that there is a force being applied to move the bottom fabric but the top fabric is only moving based on friction with the bottom fabric. This can cause the bottom fabric to move quicker than the top. A walking foot helps solve this issue by placing a second set of feed dogs on the top of the fabric to mirror the force being applied on the bottom, allowing both pieces of fabric to move evenly.
Hope that helps!
Jun 15, 2014 | Bernina Activa 140
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
There are different kinds of single needle foot, What are these?
If you take a look at this website you'll see the different feet for some makes
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
I assume you mean what are the different feet used for?
General purpose foot will have room for the needle to swing through wide stitches, but enough foot to hold the fabric and move it through against the feed dogs. This is the one you use most.
A straight stitch foot will have a little hole so that the needle only goes through a small area and the fabric can't move to give a neat plain straight stitch.
Plastic wide toe foot is good when you need to see what you are sewing onto such as applique (sewing a piece of fabric onto another with a wide satin stitch).
Teflon coated foot is good for slippery fabrics, it grips well.
A roller foot is great for textiles like leather and vinyl which don't feed nicely.
Then there are lots of feet for turning the fabric to sew it such as a rolled hem (these come in different widths so you can turn 2mm, 4mm or 6mm for example).
Felled foot (like the side seam on your jeans) joining two fabrics in a felled seam
Then there are feet for quilting and darning where you need to move the fabric smoothly in different directions, these will be small foot area and open stitching space usually.
Walking foot is a special one, part of the foot moves because a part of it clips around the needle bar and the up and down movement then activates the foot so its little teeth help to move the fabric from the top to supplement the normal feed dogs below. Pfaff machines actually built this function into their machines some years ago to give even feed from top and bottom. Great for quilting thick fabric sandwich or sewing together fabrics that want to slip or not feed smoothly.
There is also similar info here http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ which may help you to see the different uses and feet available.
Most manufacturers will sell their machine with 4 or 5 of the most used feet but often have more to buy aftermarket. And many feet between companies look very alike so if you have a clip on foot from one brand it may work on another machine with a clip on foot.
I hope that this is what you were asking.
May 26, 2011 | Sewing Machines
Top material coming out shorter than bottom. How do I put more presure on foot?
Pressure on the foot won't make a lot of difference the best way is to pin the fabric together
Mar 23, 2010 | Consew 206RB
I have a brother B757, I am making curtains and the fabric at the bottom ends up being longer than the fabric at the top can you solve this
I found out that by spraying silicone on each side of joins that it made the fabric glide through the feed dog real easy, this really works well, make sure that the silicone is suitable for sewing machines.
Nov 23, 2009 | Brother Sewing Machines
My white speedylock 1600 is being difficult.. The top threads lay and look perfect.. but the bottom threads are loose.. What can I do about this?
This machine has differential feed (top tension is different from bottom and fabric feed rate can be different from bottom). turn the dials for tension and feed rates to adjust. Adjust bottom tension to tighten bottom threads and possibly speed up bottom feed rate. Tough to say without more info.
Good luck and please rate me.
From White Sewing web site.
"Are wavy fabrics making you seasick? Do puckers leave a sour taste in your mouth? Then you need differential feed. It eliminates distortion and wavy seams when serging knits, plus it prevents puckers and pulled seams on lightweight fabrics. Turn the dial again for instant gathers.
Nov 23, 2009 | White Sewing Speedylock 1600 Mechanical...
I have an 1130 bernina and love it! with all fabric types the top material is not moving along with the bottom material when sewing seams. the lighter fabrics are puckering and the seams are anywhere...
The 1130 does not have a consumer adjustable presser foot. Check to be sure you are using the correct presser foot .Some feet are slightly different in height which is how the pressure is regulated. If this is not your problem it will need to be seen by a technician.
sewman7
Jul 14, 2008 | Bernina 1008
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
