Question about KitchenAid Microwave Ovens
When I set the timer and press the start button, the only thing that happens is "Door" is displayed on the control panel. The microwave does not turn on.
    Brigadier General:
  • 8,909 Answers
I think you have a dodgy door switch. I would get them checked.
Hope that helps.
Posted on Mar 17, 2011
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
Microwave refuses to work when START button is pressed. Oven light stays on when door is closed. Control panel seems to be working ok but nothing happens after cooking settings are set and START button...
That's probably a failed door switch or door switch mount.
It's a pretty simple do it yourself fix. See this helpful file on door switches.
You can find handy exploded views and order parts by model number here.
But if your cooktop lights failed recently, you have a damaged control circuit board, which we can usually repair for $39.95. Details are here.
Jan 11, 2011 | Whirlpool MH1150XM Convection/Microwave...
Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 19, 2008 | Microwave Ovens
We are house sitting for friends. They have a Miele Classic, wall mounted combi oven. It has a single dial at the top left of the silver facia. To activate the microwave, I turned the dial one click...
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Please reply back with your brand and full model number.
May 11, 2008 | Microwave Ovens
Door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Aug 04, 2007 | KitchenAid KBMC140HSS Convection/Microwave...
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
May 25, 2007 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
