Question about Cell Phones
Operating instructions for a B.T.Graphite 1500twin
  • 341 Answers
You can download BT Graphite 1500 user guide at following link: http://www.businessdirect.bt.com/content/uni2/documentation/4xz5/graphite_1500.pdf
Posted on Mar 17, 2011
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
How do I restore a dead key on a Korg X5?
What do you mean by applied graphite...graphite powder? That is not the solution I wouldn't think, you need to use a keyboard contact repair kit, which has a solution you paint on? Something like the link provided might be in order. Make sure there are no improper conductive bridges formed between the contacts in the PCB board surfaces. Replacement rubber pads (the part that presses down) are available from any decent service provider (try Syntaur if can't find http://syntaur.com/korg_x.html ) (beneath key) Korg Key Contact Repair Kit Replacement Keys and Parts for Korg Series Keyboards
Jan 14, 2015 | Korg Music
Bt graphite instructions
This could be due to the fact that one of your phones is off the hook or unplugged. Check and make sure that all devices are operational and charged.. Try applying a warm damply wet cloth on the back when attempting to open the battery cover..Don't forget to check the phone line itseft.
Cheers
Jan 21, 2014 | Lands Phones
My lock every couple days do not work for some reason, why? do i nee pair keys or what to do?
Hi. Try using graphite powder to lubricate the lock. Puff the graphite in, and turn the lock so that the rough part of the key is facing down, and slide the key in and out of the lock to work the graphite into the pins and springs in the lock. Then, use the key to unlock the lock several times. When the hasp is open, puff some graphite into the hole that the shackle goes into. This will free the mechanism of the lock up, and should get it to operate properly.
--W/D--
Mar 03, 2011 | Garden
Lost instruction manual for BT graphite 1500
Yahoo "user manual BT 1500 answering machine"
Fifth selection; (pdf) User Guide. You can make sure you have the correct selection by looking at the link...shop.bt.com
Click on that fifth selection and manual will load. Save pdf file
Dec 08, 2009 | British Telecom Lands Phones
Apple I Mac special edition graphite-- how do i open casing to gain access to hard drive
go to http://www.faqintosh.com/risorse/en/guides/hw/imac/imacg3dvhd/
and follow the instructions on it. It should be similar to the older imac g3
Oct 13, 2009 | Apple iMac Special Edition Graphite Mac...
My homelite trimmer string keeps getting stuck and when i tap it to release more string it doesn't the spring in it doesn't spring at all. I constantly have to stop take it apart pull enough string to edge...
It's sticking pretty good. Try what I do: Pull the head off and clean it out pretty good. Also clean where the spool attaches to the trimmer. Before you reassemble it, give it a shot of powdered graphite (I get mine at the hardware store. It's for locks). Reassemble the spool onto the trimmer. Bump it on the ground several times to distribute the graphite within the head. Now, press the head in and pull on the trimmer line. It should dispense a little line and stop, just like when the machine is in operation. If it works, you're done! If it doesn't work, you will need to replace the spool. They are available at the major hardware stores. Even if you have to replace the spool, the graphite trick is a good one. It'll keep the head dispensing line smoothly. I add the graphite probably every 7th or 8th time I rewind the spool.
Best regards, --W/D--
Aug 09, 2009 | Homelite Garden
Reloaded string empties and shreds continuously in seconds
It sounds like you may need to replace the head. It is designed to advance and stop, but your's isn't stopping. Try this: Clean the inside of the head and connection to the machine well. Put some graphite inside the spool and where it connects to the machine; be generous with the graphite. Put the head back on with some line properly wound onto the spoo (note arrows on back of spool). With the machine off tap the head on the ground enough to disperse the graphite thoroughly in the head. Now, push the head as though to advance the line, and pull on the line. If it advances a little and stops, it is working. Do this several times to be sure. If you can get it working like this, you're good to go. If not, replace the spool. Even with the new spool, occasionally put some graphite in it to keep the line advance smooth!
Best regards, --W/D--.....Please feel free to rate this solution. Thanx!
Jul 25, 2009 | Black & Decker String Trimmer Cordless 12"...
Cell Phones Logo
199 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
