Question about Sony DRU 510A DVD±RW Burner
Sony CD / DVD DRU-510A. Reads CD's and DVD's, burns CD's, but will not recognize blank DVD's. Sony support page states: 4X DVD-RW Media Compatibility Notice Please Note: 4X DVD-RW media is not compatible for recording with your drive, please use 1X or 2X compatible DVD-RW media only. Why won't it recognize 4x blank disc's anymore?
  • Sony Master
  • 1,381 Answers
Hello hdavison
Make sure you are using compatible media ( DVD-RW ? DVD+RW ? )
Otherwise , your device is defective . A new one will kost you only a few $ or £ or € and it would be useless to submit your drive to a repair office .
Best regards
fanaudi .
Posted on Mar 17, 2011
Testimonial: "fanaudi, thanks I had a blonde moment - haa! The media I tried is 4x DVD+RW. I just ordered the 2x DVD-RW discs and will see if that works."
  • fanaudi
    fanaudi Mar 17, 2011
    You' re welcome hdavison . Good luck with the new media . fanaudi .
    Guru:
  • 1,705 Answers
Well a quick check here says it should manage 4 x DVD write speeds:-
http://reviews.cnet.com/dvd-drives/sony-dru-510a/4507-3212_7-21226932.html
The only thing I can think of is that lens may have some dust on it, try a CD lens cleaning disk or a blast of air from an aerosol spray can.
After this, I'm afraid its down a replacement.
Testimonial: "Thanks, I will try cleaning it first and will go from there. "
SOURCE:
Why won't this thing read or write?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Apr 12, 2012 | Sony DRU 510A DVD±RW Burner
Can the dual layered discs be burned on the device
The Sony DRU 510A is not a dual-layer burner.
Jan 31, 2011 | Sony DRU 510A DVD±RW Burner
Whenever I try to burn a cd it fails and comes up with an error 4280 message how do I fix this problem
Hi! I had the same problem before when writing files to disc. What i did was to lower down the speed ex. from 16x to min or from 4x or 8x to 16. That should also fix your problem.
Jun 14, 2010 | Sony DRU 510A DVD±RW Burner
Sony DRU510A, will burn CD fine, but not DVD, will play DVD
Same thing is happening to me. Does anyone know of a solution to this problem?
Feb 06, 2010 | Sony DRU 510A DVD±RW Burner
Sony DRU 510 wont burn.
inside circuit belt is loose. show to computer hadware
Jun 18, 2009 | Sony DRU 510A DVD±RW Burner
Sony DRU 510A wont burb discs
if any error come that means your writer is ok only circuit loose
Can not finalize disk (cd or dvd)
I just burned 6 movies, I noticed that when it goes to finalize, it ejects before finalization is complete. I use FAB Platinum 4.1. I'm going to go into the settings and use Nero burning rom before I remove my Sony and put in my other burner (Plextor) better then Sony I think. I used Nero before and it helped, maybe it will help this time. Why 3 movies did not play, and the others did is beyond me. Dan J
Nov 14, 2007 | Sony DRU 510A DVD±RW Burner
Sony dru-510a , not playing movies
you need powerdvd or windvd which has the decoder for dvd. can it read regular data cd's ? like install a program?
Nov 03, 2007 | Sony DRU 510A DVD±RW Burner
Sony DVD RW DRU-710A won't burn dvds
sounds exactly like my old dead drive. if it cant boot from a cd its likely a bad drive
Nov 02, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Sony dru-810a dvd rw dual layer burner
try using TDK disks i rarely have a problem with them try doing a drive test using a blank dvd
Nov 01, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Open Questions:
Sony DRU 510A DVD±RW Burner Logo
308 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
