Question about Daewoo Microwave Ovens
I do have 140 pcs of microwave model KOR630B.14 of them are naot working,fusse is blowing out.Can u advise?
    Brigadier General:
  • 8,909 Answers
They are a very basic microwave. I expect you will find the diodes and/or magnetrons are faulty.
Posted on Mar 17, 2011
Samsung microwave ME21K7010DS displays C-10 when I select potato. Stats working but after about 2 min message C-10 appears. Works fine in other settings. Microwave is about 14 months old
Older microwaves can develop any number of quirks.
Instead I suggest calculate the number of cooking time minutes needed and use that for your potato.
Be sure to fork a few holes into the skin of the potato so it doesn't "blow" and redecorate the inside of your micro.
Jan 02, 2018 | Samsung Microwave Ovens
What is the wattage for ER-4010
Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
Sep 21, 2017 | Goldstar Microwave Ovens
How do I check to see if this model is in demo mode?
There's a magnetron that's been protected with fusses. Open cover and check fuses.
Jun 24, 2015 | In Microwave Ovens
Our base inside the machine won't go round
Sounds like the motor has blown, I did have this once before and I found by taking the glass plate out and turning motor top where plate rests on by hand a few times it started to work again but it might be gone anyway, you might be able to get a second hand one but a new one is about 30 pounds so might be advisable to renew machine.
May 10, 2014 | Sharp R-1405 / R-140 Microwave Oven
MICROWAVE OVEN MODEL R-1405 THE INDICATOR NUMBERS ON FRONT PANEL DO NOT WORK WHAT DO I NEED TO FIX PROBLEM?
A faily common problem. You need a new display panel to fix that. The display panel comes separate from the control board.
Feb 12, 2011 | Sharp R-1405 / R-140 Microwave Oven
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
Microwave stopped working and was hot inside.
At just 13 months old I would be inclined to get in touch with Maytag. If you make enough fuss they will repair it under warranty. but just check that the air intake and exhaust are clear of debris first.
Hope this helps
Jan 07, 2010 | Microwave Ovens
My maytag microwave lost power
There is always a fuse inside a microwave.Sometime this has only blown due to a surge,and upon replacing, the microwave will continue working.If it is something worse the fuse will continue to blow.In this case it could very well be the transformer,but there are other possible causes as well.(for example the control board or a short.)
Jun 24, 2009 | Maytag MMV1153A Microwave Oven
Blowing Fuses
never put higher fuse then what is already there can cause a fire microwave are being made more disposable now either use warranty or buy a new one i am lucky if i get one to last a year before it starts acting up cheaper to buy new one then to have it repaired
Dec 03, 2008 | Microwave Ovens
Sharp Microwave Oven R-530BK
We repair these control panel assemblies for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 11, 2008 | Sharp R-1405 / R-140 Microwave Oven
Microwave Ovens Logo
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
