Question about HP Computers & Internet
My hp pavillian does not showing any display - HP Computers & Internet
  • 784 Answers
Videochip problem!
Posted on Mar 17, 2011
Dears, Some times on my HP pavillian loptop( 4 years old) screen shown some vertical line ( Uncontable lines) and some times it is not, I have two operationg systems, while booting in to any one of...
You may be having a problem with the graphics driver of your laptop. You can try to download the graphics driver specific for your laptop model and operating system. The best to check if it is not an issue with the LCD is to attach an external monitor and check if the line appears on the external display.
Hope this simple tip helps.
May 10, 2011 | Computers & Internet
My hp laptop pavillian dv6000 shows "operating
The impact wasted your HDD. The reason your recovery DVD's will not work is that there is no OS on the HDD to recover.
You will need to do a fresh install of your OS.
Jan 07, 2011 | HP Pavilion dv6000z Notebook
How to tranfer from one pc to another with dynex c114191 Cable .this is the new one hp pavillian elite modle # e9120y. old pc is gateway 830gm
you wil need software like fastwire special for usb and network connections
pls contact me for the software for free
ben.pluijm@viveole.com
i wil send you by fileflyer
Aug 19, 2009 | HP Computers & Internet
Hp lap top will not reboot, restart nor retore
No power or computer does not turn on. Issue: No power or computer does not turn on.
Cause: No power from the computer can be caused by any of the below possibilities.
  1. Connections not connected properly.
  2. Third-party hardware.
  3. Bad power cable.
  4. Incorrect power supply.
  5. Bad battery.
  6. Bad power supply, power button, and/or power board or inverter.
Solution: Connections not connected properly Verify that the power connection is connected properly to the wall and the back of the computer. If the connections appear to be connected properly, attempt to disconnect and reconnection both ends of the cable. If you have a power strip (surge protector) or switch used to turn everything on at once, temporarily disconnect the computer from that switch and connect that cable directly to the wall. This will help verify that the strip or switch is not bad. Verify that the outlet works by connecting a different component to that switch.
Third-party hardware If additional hardware has been recently added to the computer it is recommend that you temporarily disconnect that device or devices from the computer to verify they are not preventing your computer from turning on. Note: If the computer was working fine before you added the new hardware, removing the third-party hardware did not resolve the issue, and the computer is not beeping but is turning on, please see our POST troubleshooting document CH000607.
Bad Power cable Verify that the cable supplying your computer is not bad or damaged by using another power cable. If you have a standard CRT monitor, this cable can be used in place of the computer power cable. If you have a portable computer or laptop, when the cables are plugged into the laptop you should see a power light or battery charge light. If this light is seen, this is a good indication that the power cable is good.
Incorrect power supply If you are building your own computer or if the computer has never turned on since you purchased it, it is possible you are using a power supply that does not supply enough power and/or the incorrect type of power supply. Verify your power supply meets the requirements of your motherboard and processor.
Bad battery If your computer is a laptop or portable computer that utilizes a battery for mobility it is possible that the battery may be causing your issue.
  • If your computer powers on when the cable is connected to the portable computer but not when it is disconnected, we recommend you purchase a new battery.
  • If your computer does not power on when the battery is connected and when the power cable / charger cable is connected, try removing the battery and seeing if the computer can power on with only the power cable connected. If no power is still received, skip to the final section.
Bad Power Supply, power button, and/or power board or inverter If, after following the above sections, your computer still receives no power, it is likely that a hardware component in the computer has failed. It is most likely that the power supply has failed. If you do not plan on replacing the power supply yourself or if you have a portable computer, we recommend having the computer serviced by your computer manufacturer or a local computer repair shop. If you have a desktop computer and plan on trying to repair the computer yourself, we recommend you replace the components in your computer in the below order.
  1. First open the computer and verify the power connections. You may also wish to consider disconnecting the main power cable and reconnecting the power cable to make sure it has not become loose. Also verify the power button cable is correctly connected to the Motherboard.
  2. Replace the power supply with a new power supply.
  3. Replace the motherboard.
Index
Resolved
Dec 06, 2007 | HP Pavilion dv4000 Notebook
Webcam Problems
hi i have the dv2000, same problem you will be able to find an driver at www.hp.com once you have downloaded it and installed
press the quickplay launch button > video music picture icon ,then> hp webcam
Oct 13, 2007 | HP Pavilion DV6295us Notebook
Computers & Internet Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
