Question about Raymarine RL70CRC GPS Receiver
I have an SL70 (SL72 Monitor) that does not power up. When I had the unit demonstrated to me, the unit worked fine, the scanner worked and painted a picture of the marina. When I got it home and connected it up to a 12VDC power supply, the unit will not power up. I opened the unit and have voltage (of the correct polarity) to the power switch, but nothing comes on. I even connected up the scanner and that does not power up either. I didn't pay a lot for the unit so if it is DOA, Ok, I didn't loose too much, but I know the unit worked before it was removed from the boat and I would like to get the unit working. Any suggestions are greatfully accepted.
  • 1,940 Answers
  1. When you press the power button to turn the unit on, you must press and hold until unit beeps to turn on display. Press for 3 seconds to turn off display.
  2. Make sure that the power supply cable is sound and that all connections are tight and free from corrosion.
  3. Check the system fuse.
  4. Check that the cable connecting the scanner to the radar display unit is firmly attached and undamaged.
  5. Parts for this device can be found here: http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=921&PRODUCT=2535
For technical support, you can also contact Raymarine here: www.raymarine.com/recreational/support
1-800-539-5539 extension 2444 or
(603) 881-5200 extension 2444
Here is the manual for the SL70: http://www.raymarine.com/submittedfiles/handbooks/radars/81206_1www.pdf
More information: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_adp.php?p_faqid=1184&p_created=1141934623&p_sid=NOhC_apk&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODYsODYmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1TTDcwQ1JD&p_li=&p_topview=1
Posted on Mar 17, 2011
Blinks On and Off
Hi Wickdamam, It sounds like the viewsonic power supply inside your monitor is Clamping due to a heavy load or a short circuit. The best method for getting your monitor back to normal, is to carefully disassemble the unit and clean the dust and lint from everything inside. I use a paint brush to sweep the circuit boards off. Evidently you have something shorting out inside. You will want to look for anything that does not belong inside like jelly or anything crazy like that. If you have further problems contact me at Repairtech@playstationclinic.com.
Oct 08, 2007 | ViewSonic VE710b 17" Flat Panel LCD...
Hp 3670 no longer scans to computer with vista 32 bit upgrade. Scanner will only scan out copies to printer. worked fine with windows xp
You can use Paint or a similar program to scan in a picture/document with your scanner.
Once in Paint you can select from Open the option of From Scanner.
You can change the size to fit the page in Paint and then save it to a file which can be opened and sent to a printer.
It's very basic, of course and it doesn't give you the options to set the scanner options usually found in the HP Toolbox.
Jan 31, 2010 | HP ScanJet 3670 Flatbed Scanner
I got a raytheon sl70 pathfinder gps that wont get a fixed signal the antenna is wired right but there dosent seen to be power comeing out of the cord that leads to the antenna. what should i do ????? i...
If you're using a raystar 125 antenna, you will have to power the red wire + and the shield wire - separately. Sl70's don't provide power over seatalk. Also make sure your green and brown wires are properly connected. If it's a 120 just power the red and sheild(black) and leave off the all except the yellow that's your data. If you still have nothing may probably have a problem in the antenna itself.
Jan 20, 2010 | Raymarine RL70CRC GPS Receiver
Scanner
Try updating the drivers. Take this link to Hp and either enter model number and then operating system or let Hp detect your hardware and select drivers.
http://www.hp.com/#Support
Aug 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
Aug 02, 2009 | Solis Crema SL-70 Espresso Machine
Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
Raymarine rc435
ripoli, This should site should help you now and in the future: http://raymarine.custhelp.com/cgi-bin/raymarine.cfg/php/enduser/std_alp.php?p_sid=8fkbDBti&p_lva=&p_li=&p_new_search=&p_accessibility=0&p_srch=&p_sort_by=&p_gridsort=&p_row_cnt=696&p_prods=&p_cats=&p_pv=&p_cv=&p_search_type=answers.search_nl&p_nav=foot&p_li=&p_page_head=1&p_page=1&p_page_foot=1 Good Luck, Tim
Feb 05, 2007 | Raymarine NMEA 0183 (E55059)
Raymarine RL70CRC GPS Receiver Logo
160 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
