Question about HTC HD2 Smartphone
My screen is frozen as well as a error message reading as followed,(Run FILEOP/windows/menu_FILEOP_Operation failed.
  • 846 Answers
Your software needs to be restored. T-Mobile or HTC might help you with this because it is so new. However if you dropped it (etc.) and if HTC doesn't replace it for you, You can get the part at HTC HD2 Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
Posted on Apr 11, 2011
    Scholar:
  • 96 Answers
The problem you are experiencing with your phone is due to the fact that the windows operating system running on your phone has either jammed up/crashed,hence its experiencing errors while trying to load the operating system.
Here is a solution to your problem;
1.Put off the phone completely.
2.Remove the back cover and take out the battery.
3.Re-insert the battery and put it back on.
4.The problem ought to be solved by now,but if it persists it means the final solution is to re-run the operating system on the phone,which can only be carried out by a qualified software engineer.
Thank you for using fixya.
Posted on Mar 17, 2011
Can't set HP LaserJet Pro 400 as default printer
I recently had a troubleshooting appointment for an hp printer that could not be set as the default printer. When I tried to make it the default, a message box came up saying "operation could not be completed error (0x00000709)". Other than that, it seemed to work fine. I even removed all the printer software through "Programs And Features"in the Windows control panel followed up by a Windows system registry scan. I then performed a clean install of the hp printer still no joy.
Next, I began to research the "operation could not be completed error (0x00000709)" error message on the internet. I came across a variety of solutions, which I tried in succession with no luck. I finally discovered the one that worked. It was a simple fix to the Windows system registry. This is what I did to solve the annoying little problem:
I. Type "regedit" followed by the enter key in the "search program and files" text box in the pop up menu that appears after clicking the Windows"start button" in the lower left hand corner of the Windows desktop screen.
II. Next, click "HKEY_CURRENT_USER" in the left hand pane of the Windows registry editor.
III. Then click "Software" followed by "Microsoft" and next "Windows NT".
IV. While under the "Windows NT" entry, click "CurrentVersion" and then "Windows".
V. Now, one of the entries you should see in the right hand pane is"Device". If the value for "Device" as noted under the "Data" area is anything other than the printer you are using, then highlight "Device" in the right hand pane with the mouse and press the delete key to remove it.
VI. Restart the computer so it starts with the altered Windows system registry.
After the Windows desktop appears again, you should be able to go into the"Printers" area and designate your printer as the default without receiving the "operation could not be completed error (0x00000709)" message.
Being able to designate the default printer can save you a fair amount of work over the long run. This is because you won't have to specify your destination printer in the printer dialog box - it is already selected since it's been set as the default.
Mar 14, 2014 | HP LaserJet Office Equipment & Supplies
I keep getting an error message that says, "Microsoft Outlook. Cannot open the Outlook Window. The set of folders cannot be opened. Errors have been detected in the file C:\Users\my name\AppData\Loc
To resolve this problem, use the following steps. On the Start menu click Run. In the Run dialog box, type the following command:
Outlook.exe /resetnavpane
Note:
There is a space between "Outlook.exe" and "/resetnavpane" Click OK. Note If you are using Windows Vista or Windows 7, you may not see Run on the Start menu. In this situation, use the following steps to locate the Run option. On the Start menu click All Programs. Click Accessories. Click Run.
Apr 15, 2013 | Dell Computers & Internet
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Igxprd32 error
Apr 13, 2012 | Computers & Internet
Windows cannot connect to printer. Operation failed with error 0x0000007e.
This problem happens when you are trying to share printer between 32 bit (x86) and 64 bit (x64) Windows. The 32 bit driver not compatible for 64 bit operating system. At this situation you may get error message like this "Windows cannot connect to the printer Operation failed with error 0x0000007e".
But there is an alternate way to add printer from 32 bit Windows to 64 bit Windows.
Start >> Devices and Printers >>
Then Add Printer with the help of IP address of 32 bit Windows computer.
Detailed steps with screen shots are given in the following link.
[Solved] Operation failed with error 0x0000007e
Solved Operation failed with error 0x0000007e Share printer between 32...
Apr 11, 2012 | Xerox Office Equipment & Supplies
I've received a mms message and my screen say MMS retrieval failed, how can read this message?
This often has to do with a network error, or your phone its self. The best solutions are as follows.
  1. Turn your phone off and turn it back on and attempt to retrieve the message again.
  2. If that fails, ask the sender to resend the message.
If the above solutions do not work you might need to consult with your wireless provider.
Jun 03, 2011 | Cell Phones
I am getting an error message when trying to add stuff
Not too sure if problem is with operating system or the FTM program. Check if you have enough disk space. You may also need to check that your OS works properly, there is a free program for this http://www.iobit.com/advancedwindowscareper.html
check your system, that might improve.
Its also worth to check for errors when the FTM is running, In Menu item EDIT run the option check for errors
Jun 09, 2010 | Broderbund Family Tree Maker 11 (382648)...
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
Acer computer is frozen on screen which reads press f12 or del to enter setup. when computer comes on it does not beep so i cannot use keyboard all the lights on the keyboard aare off. HELP!!
From the description you are giving, it appears that the system is not detecting a bootable hard disk drive. Hold the power button on the system till it powers off. once system is off, try the following:
  1. Ensure no floppy diskette is in the A: if system has a floppy drive
  2. Disconnect all external items (Printer, scanner, network connection) leave only video and keyboard connected to system.
  3. Try powering system on again
If the system gives the same message, try rebooting and pressing F12 ONCE at the ACER screen and see if you can get a 1 time boot menu. If you can get the boot menu, select CD-ROM, and put you WINDOWS CD in the optical drive, see if system will boot to the CD. If you can, then at the first prompt, press R to enter recovery console, and see if you can run the command CHKDSK /R (then press enter)
If chkdsk runs, then reboot and see if the error has gone away. IF you cannot run CHKDSK then the hard disk drive has likely failed and will need replacement.
Nov 01, 2009 | Computers & Internet
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
HTC HD2 Smartphone Logo
281 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
