Question about HP DESKTOP PC HP | PW525AA
When leaving the computer for 15 to 20 mins the cpu shuts down
    Scholar:
  • 60 Answers
Hi..
expecting you're using a windows based operating system such as Windows XP, Windows Vista or Windows 7.
Since the computer does not show any error messages after starting from such shutdown, this is may not be a hardware problem . It rather appears to be Power saver Setting.
Please check whether a Power Saver Policy causes this unintended shutdown.
you can review Power Saver Policy by following these steps
> On Windows XP
  1. Right click on an empty space of desktop. On popped up menu, select Property.
  2. A new window will show. On that window there will a tab for Screen Saver. On that, click on button named " Power "
  3. Then it will show available power policies
  4. Look an entry for shutdown and value set on Drop down menu right next to it. It specifies the amount of time waited before put the system into shutdown, if the system left inactive.
  5. You can specify desired time duration before computer goes to shutdown or you can even set to Disabled to completely turn this feature.
> On Windows Vista / 7
  1. Open control Panel
  2. From Control Panel, click on Power Management. You may be asked to enter Password
  3. Click on Profiles
  4. This will show current Power Saver Policy.
  5. There will an entry for shut down. Check time duration specified for this entry.
    This time specifies how much time it should wait till it put computer to shut down after an inactivity.
  6. You can either specify a desired time duration before computer goes to shutdown or you can even set to Disabled to completely turn this feature.
This feature is good to be turned on . Since if this feature is turned on, the PC shuts down itself if we forgot to shut down and thereby minimizing wastage of energy.
PS: This feature activates only if the computer is left inactive, that is no application is actively runs.
Posted on Mar 17, 2011
    Sergeant:
    Champion:
  • 239 Answers
There are 2 possible reasons. The first and most likely is that the pc is going into hibernation. If you go through to your 'control panel'. Look for 'power options' and make sure that hibernate is unticked.
The second possibility is that the CPU is overheating. In this case you need to switch off the machine and remove all the cables from it. If possible leave for 30 minutes. Put it onto a wooden surface and take off the side panels - often 4 posidrive screws on the back. (Some pc's have one screw on the back at the top. When this is unscrewed the top is removed and the side panels lift out)
Get an airduster (can of compressed air) and blow out all the little bits of dust you will find. It is also worth carefully blowing through the fan from the outside to the inside to remove all the dust I am sure is there!
Reassemble the side panels and the computer and restart.
Hopefully one of these solutions will help you
    Guru:
  • HP Master
  • 1,705 Answers
1) Could be your power saving settings, set to switch off when idle for a certain amount of time.
2) Could be CPU overheating, disconnect all power, take the cover or a side off the tower have a look inside, if it full of dust and fluff, a very gentle clean out would be order of the day. A dry soft bristled paint brush to disturb the dust and a hoover to take it away.
  • 93 Answers
Check the Power Plan settings of your Computer.
My pc shuts down on its own after a few mins
It could mean that the CPU fan has died or the heat sink is full of dust if either of those has happened raising the computer off the desk won't help because the CPU will overheat anyway and shutdown the computer so that no components end up being fried
Dec 01, 2013 | Acer Aspire Computers & Internet
Computer shuts down after 10-15 min
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
May 13, 2013 | ASUS Eee 900 Notebook
Interior lights stay on wile i'm driving my 2005 lincoln navigator
Only one bad door switch should do that
The 20 min time out is the GEM or Body Module,
which is normal only because you have a bad switch,
otherwise it goes to sleep when either front door opens
Put radio on & open a door,the radio should go off
& kill the time delay if no issues exist
Feb 05, 2013 | 2005 Lincoln Navigator Luxury
My hp pavilion dv9720us will run for about ten mins and then shut off
you can try to hover around the fan outlet the dust gathers and stops the cpu cooling down and then the cpu wiil shut down to protect the laptop from overheating if it runs longer but shuts down you will need to get in to the laptop and do the same around the heatsink fan and cpu
Jan 08, 2013 | HP Pavilion dv9000z Notebook
I love my notebook but all of a sudden its shuts down because it continues to get hot underneath and its not the battery..I log on and it may last 15 mins maybe 45min at the most...what is going on? I
COMPUTER/LAPTOP OVERHEATING
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.http://www.fixya.com/support/r5959377-overheating_computer
Jan 13, 2012 | Toshiba Satellite L455D-S5976 Notebook
My computer will not boot up keeps closing down
check how often it shuts down and if it shuts down when you start a particular application then start your computer and go to BIOS and leave it on there ( for example if your comp shuts down every 3 mins in normal mode then leave the comp on for 15 mins in bios to determine if it is a hardware or software issue then check in sfae mode the event log or error reporting if any hardware is causing the issue, update the drivers or try with new user or reinstall OS as last option.
Aug 10, 2010 | Acer Computers & Internet
Why my computer automatically shut down eventhough it working 10 to 15 mins?every time i restart it will shut down again...what is the cause? do i need to replace the new one(motherboard)?
You could have a problem with your OS, it could be viruses, or other things.
It could also be a force shut down by your motherboard. Before you replace the motherboard, check to see if you computer might be over heating. Touch the heatsink on your CPU/Motherboard. Feel if it is too Hot or Cold. You only want it to be warm.
Mar 08, 2010 | EliteGroup P4VMM2 Motherboard
Laptop just shutting down every 5 mins or so -- Just going power down and booting up until one waits -- Same issue in safe mode, on battrey, on power with abttrey disconnected, and even in bios mode....
Sounds like the CPU is overheating. Try cleaning with canned air. On the bottem of the laptop you can see a fan with laptop off and battery removed use a whole can of air to clean it. wait 5 min. replace battery and try normal start up. listen for the fan to come on if it doesn't the fan is bad and needs to be replaced
Hope this helps
Please leave feed back
Nov 29, 2009 | HP Pavilion DV6910US Laptop
Computer shuts down
  Hi,     I think you might have a cooling issue with the CPU (Main Chip). If the CPU is getting Hot it will shut the system down preventing damage. Check the  inside of the case and be sure that the fan for the CPU is functioning. You might also have your power supply checked as well...
                                            Joe < Data Miner >
Nov 01, 2008 | Computers & Internet
HP DESKTOP PC HP | PW525AA Logo
71 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
