I have used the settings, tools route but the only options about cartrdges are align and clean, there is no gauge. what else can i do? how do i get to see levels on the computer before printing.
    Guru:
  • 1,705 Answers
There may be a route via right mouse click on the printer and selecting properties. Other than that you're going to have to consult your printer user guide.
If you don't have a copy, you should be able to download one from you printer manufacturers website.
Just follow links for support and downloads entering you printer model details when required.
Posted on Mar 17, 2011
Cam timing for fiat siena 1.2 2001
There are no timing marks on this engine - the engine has to be "locked" using special engine locking / setting kit which you wil have to obtain to do the job.
I will give you the instructions to do the job for when you have the locking kit to do the job.. as follows:
Removal
  1. Raise and support front of vehicle.
  2. Remove:
      • RH front wheel.
      • RH inner wing panel.
      • Air filter assembly.
  3. Support engine.
  4. Remove:
      • RH engine mounting and bracket.
      • Timing belt upper cover,
      • AC receiver/drier (if fitted). DO NOT disconnect hoses.
      • Timing belt lower cover.
      • Auxiliary drive belt.
      • Support bracket between gearbox and cylinder block (Palio).
  5. Palio: Remove bell housing cover plate. Fit flywheel locking tool. Tool No.1.867.029.000. or equivalent commercially available.
  6. Remove:
      • Crankshaft pulley bolts
      • Crankshaft pulley
      • Spark plug leads.
      • Ignition coil and bracket.
      • Spark plugs.
  7. Fit dial gauge and adapter to No.1 cylinder. Tool No.1.860.895.000.
  8. Turn crankshaft to TDC on No.1 cylinder. Set dial gauge to zero.
  9. Ensure notch in rear of camshaft aligned as shown.
  10. Install camshaft aligning tool. Tool No.1.870.823.000
  11. NOTE: If camshaft aligning tool cannot be fitted: Turn crankshaft one turn clockwise.
Installation
  1. Ensure No.1 cylinder at TDC by turning crankshaft slightly clockwise and anti-clockwise. Use dial gauge .
  2. Ensure camshaft aligning tool fitted correctly
  3. Hold camshaft sprocket. Use tool No.1.860.831.000/001
  4. Slacken camshaft sprocket bolt
  5. Fit timing belt in following order:
      • Crankshaft sprocket.
      • Water pump sprocket.
      • Camshaft sprocket.
      • Tensioner pulley.
    NOTE: Observe direction of rotation marks on belt.
  6. Fit tensioning tool locating pegs to tensioner pulley holes -Tool No.1.860.745.100/300. Ensure tensioning tool arm is horizontal.
  7. Set weight at 70 mm mark on scale bar.
  8. Hold camshaft sprocket
  9. Tighten camshaft sprocket bolt - Tightening torque: 70 Nm.
  10. Remove aligning tool
  11. Turn crankshaft two turns clockwise.
  12. Ensure No.1 cylinder at TDC by turning crankshaft slightly clockwise and anti-clockwise. Use dial gauge
  13. Ensure camshaft aligning tool can be fitted - If not: Repeat installation procedure.
  14. Tighten tensioner nut to 28 Nm
  15. Remove:
      • Tensioning tool
      • Camshaft aligning tool
      • Dial gauge
  16. Install components in reverse order of removal.
  17. Tighten crankshaft pulley bolts - Tightening torque: 20 Nm + 90°.
Jun 26, 2016 | Fiat Cars & Trucks
Printer alignment
first clean using tools and then allign. GL
Aug 19, 2013 | Brother MFC-440CN InkJet Printer
How do you select most use of freeways to avoid back roads? My Magellan was easy to use in that regard.
Go to the Tools > Settings > Navigation > and press the button under Avoidances.
Use the arrow down and place a check mark in the box beside Unpaved Roads and then press OK.
Also, go to the Tools > Settings > Navigation > and setting the Route Preference to Faster Time will usually route using freeways. This is not always the case, as some secondary roads are paved and the unit will route to them if it calculates that this will be a faster route.
It is usually a good idea to familiarize yourself with an unknown route. This can be done after creating the route and touching the map screen. Zoom out to view sections of the route. Via points can then be added to modify the route as necessary.
Sep 28, 2011 | Garmin nuvi 1450 GPS Receiver
Hi I would like to set up a route and slightly
Routes can be edited to add or remove points by selecting the route and editing it while in the nuvi.
This can be done by going into the Tools > Routes, select the route and Edit then save. The route can also be edited by using the Where To? > Routes, select the route and Edit then save.
Sep 23, 2011 | Garmin nuvi 1450 GPS Receiver
I want to bet the best and quickest route rather than the scenic -help
To obtain the fastest route all that you have to do is adjust your routing settings, to do this go into Tools > Settings > Navigation in this menu you should have the option of "fastest time" or "shortest distance"
Hope this helps!
May 10, 2011 | Garmin nuvi 260W GPS Receiver
Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Cartridge alignment using vista
Option 1:- This method of aligning or cleaning ink cartridges will work for most computers and printers. Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the following steps are not the same as those you see on your computer, skip to the next option. Each option does not work on every computer.)
Click Start, then Printers and Faxes.
Click the desired printer icon to highlight it.
Click File, then Printing Preferences.
Click the Services tab.
Click Open Toolbox.
Click the desired task.
Option 2:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer)
Click File and Properties.
Option 3:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
Double-click the XXXX Printer Assistant icon on the Desktop.
Click the Utilities button or the Tools and Updates button.
Click the Printer Maintenance button.
Option 4:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Right-click the Printer icon on the Taskbar.
Click Open Toolbox.
On the Device Services tab, click the desired task.
Option 5:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Click Start, Programs, HP DeskJet (your printer) series vX.X, then HP DeskJet (your printer) series vX.X Toolbox.
Click the Device Services tab.
Option 6:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, go to one of the other options. Each option does not work on every computer)
Click Start, Programs, Hewlett-Packard, HP DeskJet XXXX series, then Printer Assistant.
Option 7:-Double-click the HP Director icon on the Desktop.
Click the Utilities option.
Jul 17, 2008 | HP DeskJet 5150 InkJet Printer
Heads on printer
go to the menu and select tools and settings. There should be an option to clean the heads.
If you mean clean the cartridge, take it out and using a sterile swab (not a q-tip), or a swab that doesn't release any fibers, dip it in rubbing alcohol and wipe the ink area with the swab. Keep doing this with a new swab each time until no ink is left, then print a alignment page.
Jun 18, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Ink cartridge problem
you may find that doing a clean and alignment assists with this problem.
Mar 31, 2008 | Canon PIXMA MP510 All-In-One InkJet...
12 people viewed this question
jasbo
jasbo
