Question about Soundstorm 1FD1500 Car Audio Amplifier
The protect mode light is red on my amp. when i power everything up it sounds completely normal. there is power to the amp terminals, but the amp puts out no power. The ground did come lose and may have shorted. Need to know how to fix amp.
    Genius:
  • 1,126 Answers
You need to take to a shop, the secondary and the primary are usually take out, and sometimes they are not worth fixing, you can buy new for what they charge on repairing.
Posted on Mar 17, 2011
Well i was driving one day and my subs just whent out so i bought brand new wires and hooked everything up but the power protector light turns red whenever uu turn it up past volume 10 i really do not know...
It sounds like your amp is going into protection. I know it's frustrating, but this is actually a good thing. If you subs you have are drawing too much power and the amp can't keep up, it will shut off instead of melting the board. Usually, the protection mode only last a few seconds. The user normally turns the music down that the protection shuts off and the music plays again. I recommend looking at a larger amp for your subs, if you are going to play them that hard.
Aug 14, 2011 | Car Audio & Video
When i put on power protect light come on
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible causes, do the following. Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still shuts down (goes into protect mode), the amp almost certainly has shorted output transistors and will need to be repaired. If the amp only shuts down when it's driven to relatively high volume, you need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts on either the B+ or remote line, you need to check the wiring feeding whichever line is too low. If 'both' the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Dec 15, 2010 | JBL BP1200.1 Car Audio Amplifier
I bought a MTX Terminator amp and the light is red when I turn it on, but it works. Red usually means protect mode but it works fine. Should the light be red or green?
all depends on that amp... if there was an issue it wouldnt work, and the light would be by a protect symbol... if its just red next to the power symbol i say no issue.
Feb 18, 2010 | Car Audio & Video
Protection light flashes on and i get nothing
Hello shwoop22,
It sounds like power is shorting out or the amp is defective. With the fuse removed, use a multimeter set to ohms and check between the power terminal to ground.
The protection light will normally come on if the amp overheats (for example when running with too low impedance), or if the speakers are shorted.
Hope this helps.
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
I have an older red sony xplod 500w 4ch amp. the power/protection light is glowing red. what does that mean and how do i fix it? I have no sound.
The protection light comes on if the amp overheats or if the speaker outputs are shorted.
Turn everything off and check all of your speaker wires for shorts. When you locate and repair the short, the protection light should go out and your amp will work normally again.
Hope this helps!
Mar 26, 2009 | Car Audio & Video
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Red protection light
If the amp is going into protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Sep 12, 2008 | Nitro BMW-482 Car Audio Amplifier
Protection Mode? amp wont start
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 29, 2007 | Power Acoustik LT960 Car Audio Amplifier
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Soundstorm 1FD1500 Car Audio Amplifier Logo
117 people viewed this question
Top Soundstorm Car Audio & Video Experts
xxxxxx xxx
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
