Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Inside the case there is a black lever, goes to brush, on each side with a spring that is broken. I got the replacement parts however, I don't understand how it is installed. It appears to hold tension on the brush retainers but I can't figure out where the spring is positioned to apply any tension. Any help would be great. Additionally, although I have the service/repair manual, it does not show the routing of the hoses. I had it repaired before and still never funtioned correctly. I am guessing that one or more of the hoses was installed incorrectly. A schematic would be of great help.
  • vietnamve870 Mar 17, 2011
    Previous reply simply echoed the fact that I need a manual which I had already downloaded and referenced in my questions. The manual does not describe the installation of parts I quieried and does not show a routing for the hoses.
  • 10,865 Answers
Hello Viet... here is a link to the parts diagram for your Bissel showing exactly how it goes. http://www.searspartsdirect.com/partsdirect/part-model/Bissell-Parts/Power-steamer-Parts/Model-16981/0116/0644100?blt=05
Joe
Thanks for choosing Fixya!
Posted on Mar 18, 2011
    Genius:
  • 1,196 Answers
I will suggest you check the link below for what you demanded for, i think schematic should help rectify the issue,
ewzealand.bissell.com/images/.../upright_deep_cleaner_repair_guide.pdf
Type the above link on your web browser.
Posted on Mar 17, 2011
My floormate leaks water on the floor in puddles, even when I am not holding down the lever to wash.
Ok when replacing the Spring stem and rubber seal. Put the spring on the stem set it in the hole of the solution tank carefully hold it steady then pull the stem out slip the rubber seal onto the stem with the cupped side facing down toward inside of the tank press it over the rim on the stem so it stays in place then take the stem slip it into the solution tanks hole inside the spring and press the rubber seal into the inside of the tank.
I posted this so no one else goes threw the trouble I went through until I figured it out for my self I lost the parts and did not remember how the thing went back together and could find no help anywhere. Good Luck, Ray
May 26, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Brushes won't spin anymore
There is a spring that goes on an arm, #32 in the picture. It actuates the turbine so the brushes will turn when the handle is tilted back, and stopped when upright. This might be where that spring goes. You may have to take the top cover off to put in on. After you get it on, and the brushes still don't turn, look up in the square hole where the shaft on the brush block goes into, turn the unit on and see if it is turning, if not then the turbine either needs to be taken apart and cleaned or replaced. The turbine is what drives the brushes.
Mar 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
My roller bar doesn't seem to be working, but I checked the belt and it appears to be fine, but a bit loose. Is this the problem? dial on front to determine heighth is also very loose and does not click...
If the brush roller stalls when it comes into contact withthe carpet, it might be that the tensioner spring has broken off. This is adesign flaw in the Eureka4870. The symptoms are: 1) brush spins until it contacts the carpet then itstalls, 2) the brush lever for setting floor/carpet is loose and lacks a firmsetting, 3) vacuum no longer has the feel of being self-propelled on carpet. Itis not very easy to repair and I don't know if a replacement tensioner iscommercially available. To fix it yourself:
  1. Remove the base plate by the 3 Phillips screws.
  2. Remove the brush roller and belt.
  3. Remove the black accordion hose connecting the motor housing to the clear vertical riser on the side of the vacuum. Unscrew it from the riser. Then disconnect the accordion hose from its black connector that screwed into the riser. Then unscrew the Torx T-20 screw that holds the bottom of the hose into the motor base. Then draw the accordion hose out through the underside of the vacuum.
  4. From the underside, remove the 3 Torx T-20 screws that hold the red top cover in place. They are located between the brush roller and the two small height adjustment wheels. The middle screw holds the height adjustment knob. The other two straddle the height adjustment knob.
  5. Turn the vacuum upright and remove the red plastic cover. This is the most difficult step. Use a flat screwdriver to pry it loose in the hole where the accordion hose fed through. On the other side, where the foot operated upright release lever is, you will have to pry the red cover off. I broke the red plastic loop from here. But it still reseats OK.
  6. Still upright, remove the belt tensioner by the 5 Torx T-20 screws, including the one connecting to the slotted arm (it has a wide cylinder under the head). Before removing the piece, note that there appears to be another mounting hole like the four standard mounts. This is the anchor for the spring which applies tension to the tensioner. The other anchor point for the spring has probably broken off, and the spring might be dangling loosely or even missing.
  7. Remove the tensioner unit. Locate the other anchor point, which is probably a broken tab with a hole as the anchor point, broken through from the high tension of the spring. This is the aformentioned design flaw.
  8. Drill a new hole near the broken tab. I drilled two, at right angles to each other. Drill small holes so as to not weaken the remaining plastic. I drilled ~1 mm. Holes should be between the two anchor points so as to not make the spring stretch longer than the original. Plus, a longer anchor point will interfere with the butting of the plastic edge when in the stretched position. If the spring is already lost then use a replacement that is ~1 inch long (total length) with hooks at each end.
  9. Reassemble the tensioner device. Check the operation of the tensioner lever to ensure smooth, firm locking.
  10. Reassemble the red plastic cover (3 screws including the height adjustment knob).
  11. Reassemble the accordion hose, brush roller, belt, and base plate.
It now works as good as it every did. I will next be seeking a replacement tensioner device from Eureka or a shop, since Isuspect this modification may eventually weaken and break. The plastic springanchor points are definitely a poor design by Eureka.
Sep 18, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
Model 8975-C - broken foot lever
I'm fairly upset with Bissell over this issue and considering switching to a better brand after constantly having to replace this item on every vacuum of theirs I've had. It is shocking that they would have a part that gets stomped by your foot and jerked with the entire weight of the vacuum made out of cheap plastic. The curved piece acts like a spring to hold the vacuum upright. Can you imagine a curved leaf spring made out of plastic?? In any case, they call this an "internal part" and therefore not user serviceable. You have to call their 800 number to get a dealer local to you, usually a sewing and vacuum place, and then get them to sell you the part. Otherwise, you are going to have to take the vacuum to them and have the dealer replace it.
Sep 07, 2009 | Vacuums
Bissell Shampooer, The brushes will not stay up so can,t push it.
Did this start happening after you removed the clear side pieces, to clean around the brushes? You may have loosened or removed the black plastic arms that hold the brushes in place off the floor. One goes on each side, and is mounted to the Bissell with a silver screw with a built in washer. The brushes fit inside these two arms, and they are also held in position by the black belts. The big one goes around both brushes on the left side as I face the machine. The small one goes around the back brush and a small cog on the right side, as I face the Bissell.
Nov 15, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Sep 17, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Problem with a WindTunnel 2 Extra Reach Bagless Upright (U8351900)
My dad fixed it by putting the spring under the arm lever and the roller on the outside part of the belt than in the inside as I have been trying to do.. I did however put one part of the spring in the right area of the vacuum. In a hole on the bottom area of the inside. The spring that is bent in a 90 degree angle doesn't go on top of the extend part of the arm lever but underneath. My dad did wounded the spring a bit tighter than it original is. That fixed what many days and hours of my frustration in less than 5 minutes (That's how long it approximately took my dad to fix it and in one try)
Jul 12, 2008 | Hoover U6660-900 WindTunnel Bagless...
Valve actuator, arm & spring assembly
Could not find a picture of this installed, I have replaced this spring and it is hard to do. You have to put the straight prong of the spring unto the valve arm, you will see a spot for it to be at, then wind the other end of the spring around until it goes into a slot, then get it all together on the agi housing before it comes apart. Hope this makes sense.
Feb 15, 2008 | Hoover U6660-900 WindTunnel Bagless...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
42 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
