Question about Defender H.264 8-Channel DVR - Surveillance Systems
My system is locked and it says I need a device id # user and password. Is there a default number?
Need to reset my blackberry id and password
Not too much you can do except reset the device to factory defaults and reset up your email, contacts, etc. You should be able to continue to enter in passwords until a point that it will "wipe" device. From there, you can reconfigure your device.
Dec 30, 2013 | Research In Motion Blackberry Curve 9360...
Faget id password
USER LOGIN" device id 000000 end password ??????
Aug 09, 2012 | Digital Peripheral Solutions New Q-See...
I need to know the user id and default password for a datamax barcode printer, could you help? Thank you.
You can try "sysadm" for the password using the user id blank. If you have a model number I might be able to get a better answer for you.
May 04, 2011 | Computers & Internet
WHEN I HHOK UP MY ROUTER I LOSE CONNECTIVITY TO MY DEKTOP. ALL WIRES SRE CONNECTED PROPERLY
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jan 12, 2011 | NetGear WGT624 Wireless Router
Forgot asus RT-G32 router login password. How to change the password?
You must perform a factory reset using the reset button on the rear the device. You will then have to login using the factory default user id and password, create your new password, then reconfigure your router to your system as all settings were reset to factory defaults.
Dec 19, 2010 | ASUS RTG32 Router
Resetting router password?
Aug 11, 2010 | ASUS WL-500gP V2 Router
How to reset rt-n12
Aug 03, 2010 | ASUS Computers & Internet
How to set up WEP password for my Motorola WR850G wireless router?
I got this info from the online User Manual:
  1. go to web address http://192.168.10.1/
  2. Enter the User ID. The default factory setting is "admin"
  3. Enter the Password. The default factory setting is "motorola"
  4. Click Control Panel > Device Security
  5. In the Login User ID field, enter your User ID. Create an ID that contains multiple casesensitive characters as well as numbers. It cannot be longer than 64 bytes.
  6. In the Login Password field, enter your Login Password. Create a password that contains multiple case-sensitive characters as well as numbers and symbols like “_ + )”.
  7. Re-enter your Password.
  8. Click Apply.
  9. Once the settings have been accepted, click Restart and log back into the Configuration Utility using your new User ID and Password.
  10. Select Wireless > Basic.
  11. Change the SSID to a user-friendly name and click Apply.
  12. Navigate to Wireless > Security.
  13. Select WPA-PSK from the ESS Authentication options.
  14. Select TKIP from Encryption Status options.
  15. Click Apply and then click Restart. Your wireless security configuration is now complete.
WEP is easily hacked by hackers. WPA-PSK with TKIP encryption is the newest, most secure wireless security measures and you can follow these directions to set it up this way.
Hope this helps you out! If so please give me positive rating (4 thumbs up)
Jan 03, 2010 | Arris Wireless G Broadband Router (wr850g)
I cannot find my user id and password.
Can you please tell us the exact model number of your device? You can find it at the bottom of the device itself.
Just in case you haven't tried it yet, Motorola's default username is admin and default password is motorola.
If the defaults are not working and you can't remember your password, you need to reset the device by holding down the reset button for 20 seconds at the back of it then turn off for 10 seconds. It should be back to defaults which is admin and motorola for username and password.
Jul 26, 2009 | Arris SURFboard SBG900 Wireless Router...
D Link DIR 635 - need to reset user name and password !
You can press the reset button on the DIR-635 which will reset the device back to it's factory defaults. Then connect using the factory default user id and password. (ID: Admin password is blank)
Mar 17, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Defender H.264 8-Channel DVR - Surveillance Systems Logo
189 people viewed this question
Top Defender Home Security Experts
Tom Chichester
Carlyle Houlder
Carlyle Houlder
Level 1 Expert
Jennies de leon
Jennies de leon
Are you a Defender Home Security Expert? Answer questions, earn points and help others
