Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Just wanted to ask what EXACT info i need to order a COMPLETE engine rebuild kit for B&S INTEK V-TWIN 22 HP? And also where ONLINE would be best place to order? Thanks Rick
  • 3,740 Answers
Hi Rick and welcome to FixYa, I am Kelly
B & S does not make a complete overhaul kit other than gasket sets or short-block assemblies.
Most of the time the list of parts will be:
- Rings http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=44K777-0027-E1&dn=35620003B
- Gasket set (item 358A) Below
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=44K777-0027-E1&dn=35620002
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=44K777-0027-E1&dn=35620004A
- Intake and Exhaust valves (Item 34 and 33 above) These must be hand lapped with oil and valve grinding compound both coarse AND fine grit until the valve seating faces have a shiny ring all the way around the seating area.
- You only need to replace the connecting rod if the bearings are excessively worn: (Item 29 below)
http://www.briggsandstratton.com/engines/shop/parts-and-accessories/illustrated-parts-list/?modelnumber=44K777-0027-E1&ipl_id=144650
The repair manual is PN 273521 but can be found on-line here:
http://www.mymowerparts.com/pdf/Briggs%20&%20Stratton%20Service%20and%20Repair%20Manuals%20Spec%20Charts/273521%20Twin%20Cylinder%20OHV%20BRIGGS%20&%20STRATTON.pdf
The only other area of concern would be the oil seal in the magneto area if the engine was constantly operated in an extremely dirty environment.
Thanks for choosing FixYa,
Kelly
Posted on Mar 17, 2011
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Why is my 22 hp 42 inch deck craftsman rider mower oil leaking somewhere in th fron of the engine
i need more info where is the leak near also check oil level if its to full it will blow by to the intake
Jul 29, 2012 | Briggs & Stratton Briggs Stratton Intek V...
New battery, new starter & still problems starting
Hello! How long have you owned it? Question is directed at the carb and fuel pump...I would suggest rebuilding the carb with kit and replacing the fuel pump at the same time...see photos below...There are a couple of different fuel filters; one for a non- fuel pump (gravity feed) and one with a fuel pump...Your engine requires the fuel pump filter...dirt and varnish build up in the carb and pump especially if the wrong filter is installed...Buy a gallon of carb cleaner with the tray inside...
Guru...saailer
Genuine OEM Part - Manufacturer #808656...$18 Fuel Pump
Genuine OEM Part - Manufacturer #691035...$6 Filter
Genuine OEM Part - Manufacturer #797890...$45 Rebuild Kit
Feb 13, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Gas in block of briggs 18 hp engine
Replace the gaskets on your motor. You are going to have to buy a gasket set in order to complete this. As long as you have not tried to start it, you will not have any other issues with your engine. But if you have tried to start the motor then you can possibly of hurt the valves or the piston. So if you did not try to start it then just rebuild the engine with the gasket kit, and everything will be fine after that
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Does the exhaust vavle have a stem seal on a intek twin cylinder?
Most do not. Check your exact model/type/code numbers on the parts lookup site here.
Sep 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
586 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
