Question about Yamaha RX-V2600 Receiver
Yamaha RX-V2600 I can not access my receiver's on screen menu when using the the GUI button on the remote control? each time I select it the receiver screen displays the message GUI RX V2600 and I can not go any further it will not let me access the menus so I can make manual adjustments,
  • 4 more comments
  • rappitup1 Mar 18, 2011
    Thanks, I will try that, I have tried everything else including master reset and nothing has worked yet. This option is to simple and will probably work, like always, I hope!!!
    will let you know.
    Harold
    Getting back to you on solution for my problem, I left the receiver unplugged for 3-4 hours just plugged it back in and tried to access the menu screen, no luck I still get the same message and can not scroll to any options? any more ideas.
    Harold
  • rappitup1 Mar 20, 2011
    That didn't work, any other ideas?
    Thanks
    Harold
    Thanks Jackpot,
    That didn't work, any more ideas?
    Harold
    Hi Jackpot, no luck I had tried that already but tried again.
    Hi again, yes I had already tried this one also, but tried again, no luck? I think I might have a processor problem due to the remote works all functions with out a problem, everything I had already tried that should have worked hasn't, unless there is someway to manually test or check the main processor with out having to send the unit in. I am still open to any other suggestions so I don't have to unhook the many wires going to this system.
    Thank you,
    Harold
  • 2,574 Answers
Perform a master reset :
Here's How -->Set the master switch to OFF. Press and hold the Straight (Effect) button behind the front panel, then turn the master switch to ON. This takes you to the advanced Setup Mode. Use the program selector knob to get to User Preset, switch this to RESET. Turn the unit off via the master switch. Next time you power the unit on, all the factory settings should be restored with the exception of system memory and auto setup settings.
Posted on Mar 18, 2011
  • 1 more comment
  • Reparatii PC - Service IT
    Unhook all HDMI connections unplug the Yamaha receiver and your TV from the wall outlet then try again.
    Start your receiver on Diagnostic Mode
    Press the "STANDBY/ON" key while simultaneously
    pressing those two keys of the main unit as indicated in the figure below.
    There are 18 MENU items, each of which has some SUBMENU
    items.Select the menu using PROGRAM knob.Select the sub-menu using (Forward) and (Reverse)
    keys of PRESET/TUNING.Go to Factory Preset.This menu is used to reserve and inhibit initialization of the back-up RAM. The signals are processed using EFFECT OFF.
    Use PRESET INHIBIT.Select this sub-menu to protect the values set by the
    user.
    Genius:
  • 1,126 Answers
It is possible that the main processor in the unit might have some garbage in it, do to a small power surge, and if you unplug the unit from the wall for 40 Min., it will reset back to normal.
Posted on Mar 17, 2011
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
Yamaha rx v2600 no audio at . hdmi cables ok. good video
Check the GUI menu for HDMI control and the Audio Pass thru setting. If you still have an issue, Set the Yamaha for "AUTO" on any audio input . That can be done thru the GUI menu or the hard button on the front of the receiver. Check your "Audio Output" settings on your Devices as well. ie DVD, Cable Box, Sat Receiver, etc. If you still have no audio, post a comment with the makes and models of all connected equipment and we can help you sort it out. Hope this helps
Jun 01, 2011 | Audio Players & Recorders
No sound from subwoofer on tuner and cd listening
If you have video running thru the receiver to your TV it's alot easier to see the menu. when hooked up to a TV press the Menu/GUI button on the Yamaha remote, when you get the on screen display choose "manual setup" and navigate to "Speaker Settings" arrow up or down to "Subwoofer" options are "LFE" "Sub" or "Both" choose "Both" and "enter/select/or ok" Now, if it still is happening, it means somehoe you have set up a user preference on those two inputs to have no sub. You have to navigate thru the menu to inputs and audio and check your settings. If you need more help, it is in the manual. If you don't have the manual, you can download it at www.yamaha.com/usa click on Home audio products then type in RX-V863 in the search box on the left. You may have to register to use their site files, however, it's free and you won't get spammed by Yamaha nor will they sell your email address. anyway, your problem is in your setup menu. Take your time and don't get frustrated! you've got a killer receiver!! Hope this helps
May 21, 2009 | Yamaha RX-V863 Receiver
No Gui
Does the GIU show up on the receivers screen? if so, scroll thru the menu to Manual(right click)-Video(right click)-On screen(right click)-(should be set to "always") If still persistant, post a comment and I'll help you further. Hope this helps
Jan 15, 2009 | Yamaha RX-V2600 Receiver
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
No video
Turn the "Video Conversion" to "On" if that's not it post a comment and we can dig further. Hope this helps.
Nov 17, 2007 | Yamaha RX-V2600 Receiver
Outdoor speaker hook-up
Go into the manual setup on the GUI then go to the zone 2 and zone 3 setup. If you are using only the power from the receiver to power the speakers, make sure the setting is for Zone 3 amp "INT" if you still have no volume, on the front of the receiver look at the display, make sure "zone 3" is lit up then use the small remote and turn up the vol. if it's on you will see "zone 3 vol" and the bar going up it should be ok. if it says "fixed" it thinks you have an external volume control, if you do, make sure it's "on" at about 12 o'clock and test. If not, you need to switch it in the on screen "menu" or "GUI" button, follow to zone 2 & 3 vol control and make sure it is set to variable. If you still have no vol post a comment and we can dig further. Hope this helps
Aug 18, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V2600 Receiver Logo
979 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
