Have error: C6000 on Kyocera KM-3050 - Office Equipment & Supplies
  • mrmr_bash200 Jan 31, 2009
    bluetooth doesn"t work and the phone said error when i active bluetooth
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Posted on Sep 25, 2008
Posted on Jan 14, 2009
    New Friend:
1st Attempt: 1087*2 enter U163 EXECUTE Restart the Machine
2nd Attempt : replace fuser Assembly
3rd Attempt: replace the power source PCB.This problem at times come due to faulty of any connection from power board wires which connects to fuser unit if that problem persist change that cables and replace anew one but the better way replace the fuser unit
Have error: C6000 on Kyocera - error-c6000-kyocera-qhqvplscunpf0c3m5glqqdsr-2-0.jpg
Posted on Jan 28, 2015
3 Suggested Answers
  • 62 Answers
SOURCE: C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Posted on Mar 10, 2010
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
Caller service C6000 in kyocera km 2035
Fuser heating Error
enter into programming
1087 1087
Then enter 163 then Press Print Key
Dec 03, 2013 | Kyocera Office Equipment & Supplies
KM 2810 error C6000
kyocera mita KM-2810 error code C6000 how to re-set and fix it
Feb 06, 2013 | Office Equipment & Supplies
simulation mode
execute that..
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Service code for this printer came up C6000 what
This is a fixing unit error. If you have had a power outage or your power has flickered it maybe able to be reset with out parts. Go to www.gfbm.net and call thier number and they should be able to reset it over the phone at no charge.
Feb 18, 2010 | Kyocera Mita KM-5035 Printer
Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
May 26, 2009 | Kyocera KM-1505 Copier
C6000 Error message on Kyocera Mita KM-C3232 Printer
the c6000 error may be resettable.
the password will be 3200 or 6482.
once inside you need to be in copy mode and do the following
punch into the keybord 1087 1087
once you see 000 on the screen punch in 163 and hit the green button
you will then see the reset sequence, follow this and it should work.
please report if this works
Mar 20, 2009 | Kyocera Mita Office Equipment & Supplies
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
4,868 people viewed this question
k24674
jasbo
jasbo
