Question about Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Double oven Model #WW30430, HELP! Upper oven will heat and bake accordingly, But only in afternoons, Not in the mornings ??? Thank you so much! Chalya Castagna
SOURCE: Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Posted on Dec 25, 2007
  • 412 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Check the Heating Element of your Oven.......
Posted on Mar 20, 2009
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
See this thread:
http://www.bobvila.com/BBS/Jenn_Air_Oven_door-Appliances-1-F3784.html
This worked for me (or at least helped the repair guy get the right parts for my model). Had to replace both the hinges and the hinge brackets. Seems to be a defect in these Jenn-air ovens going back to about 2006. After the parts replacement, the door lines up better, but still does not feel like it really closes solidly. At least glass on the door lines up better with the glass on the control panel.
Posted on Aug 09, 2009
SOURCE: WW30430
lower oven gives Fr code when turned on
Posted on Feb 02, 2010
I have an older jenn air model ww30430 and I cant get the fan to turn off or the upper oven to work. any suggestions
if your unit is switch position is the upper heating element is have convection? you cannot turn off the fan,but if your unit have separate option to choice the other option to oparate separately the upper heating element this one can be use.
Dec 24, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Oven upper element does not turn off ww30430
Here is a tip that will help you figure out why your oven will not shut off...
Electric Oven Problem Oven will not shut off
heatman101
Sep 02, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I have a double oven. Model WW27430. The top oven will not heat. The bottom is fine. I was told that is was the relay board. which I replaced and I am still having the same problem. Could both...
Looking at the schematic I see 2 possibilities:
1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
2. There are a relay board for each oven. Be sure you changed the right one.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | Jenn-Air WW27430P Stainless Steel Electric...
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
The upper oven has faulty code 4d22 every time i try to clean
I just tried the suggestion to cut the power to the oven from the box for 1 minutes, and it worked! I feel like I just earned a day's pay!
Dec 29, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
WW30430
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air JJW8230D Electric Double Oven Logo
105 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
