Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Mi tv. hitachi modelo 50v500, no enciende, solo los focos de colores indicadores de que esta encendida, pero no osila, no enciende no hay audio, gracias por su ayuda
5 Suggested Answers
  • 2336 Answers
SOURCE: ayuda
Te recomendaria que utilizes un transformador variable para que puedas hacer mediciones del voltaje que alimenta la seccion horizontal. Me parece que la seccion horizontal esta recibiendo mucho voltaje y es cuando se activan los circuitos de proteccion.
Si usas el transformador variable empieza con 80VAC y mide la DC en tu TV, si en la entrada de el regulador de voltaje tienes mas o menos 130VDC a la salida tienes lo mismo, el TV te funcionara. Despues incrementa es voltaje a 100VAC y vuelve a hacer las mediciones.
Si despues de incrementar el AC a 110VAC el TV hace lo mismo, trata de medir la DC en la salida del regulador de voltaje. El voltaje aceptable seria de 130VDC a 135VDC.
Suerte.
Posted on Jan 16, 2008
  • 247 Answers
SOURCE: recuadro negro en el centro de la pantalla modelo 55fx20b hitachi
in english please
Posted on Jan 11, 2009
bbl242003
  • 1637 Answers
SOURCE: No enciende tv. La luz
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
Tv lg 32ld330 enciende con sonido y sin brillo
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
Aug 18, 2012 | Televison & Video
Nesesito saber el codigo para un tv mitsui
Mitsui 0067 0586 0517 0039 0265 0041 0385 0102 0066 0247 0324 0401 0463 0473
0393 0609 0485 0193 0379 0546 0065 0238 0075 0225 0221 0365 0574 0744
1067.
Feb 06, 2012 | Motorola Mobility DRC800 Universal Remote...
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
No enciende las vocinas para mi computadora son logitech x-530 quiero verificar como puedo cambiar los fusibles o verificar cualquier cosa que sea para cambiar pero como destapo los subwoofer para...
Primero trata con otra fuente de energia electrica otro tomacorriente u otro sitio a ver si no es el sistema de cornetas, para abrir el sub buffer solo encesitas destornilladores y verificar dentro el estaod de los componentes si tienes voltimetro mejor, cuidado con hacer cortos. pero no hay uan guia basica para eso, solo saber lo que haces.
Mar 14, 2011 | Logitech X-530 Computer Speakers
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
TV Konka modelo K2038U. No enciende.
Muchas televisiones tienen reguladores ,si ese regulador no esta dando lo que tiene que dar hay que cambiarlo,tambien puede haber un corto en la linea y eso esta manteniendo bajo el voltaje,hay que chequiar los filtros(capacitadores).Suerte
Sep 06, 2006 | Konka K1369U 13" TV
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
