Question about Brother Office Equipment & Supplies
Have a brother MFC 215 and it has an error message 4F It is unable to print
  • spullin Aug 02, 2008
    Many thanks for your help, will give it a go and keep fingers crossed.
  • 659 Answers
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
this is not a 100% fix but might lead to a fix.
Posted on Aug 02, 2008
  • Wesley Gardner
    Wesley Gardner Aug 02, 2008
    4F means that the purgeunit is broken and that there is a problem with printhead, too. Solution is to change unit and head
    Maybe brother has a replacement or you can find a unit with a broken scanner you can buy for cheap for the parts to swap.
How to fix Brother printer J415W with error message "Unable to Print 4F
defective scanner you must change scanner or replace motor inside in scanner.
Jul 30, 2016 | Brother MFC-J415W Multifunction Inkjet...
Troubleshooting : unable 4f cant print
Error 4f mean the head drive voltage has dropped from the high to low level in an abnormally short period.This mean your printer need new print head.This will cost you just as a new printer, then think about new printer.
Nov 04, 2009 | Brother Multi-Function Center MFC-240C...
I am getting the unable to print Error 4F message on my Brother MFC 5440cn printer
Error 4F:
The head drive voltage has
short period.
Piezoelectric (PZT)
ceramic actuator
defective
You need to replace the print head.
Oct 06, 2009 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to print. Error message Machine Error4F
here read this:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
905 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
