How to bleed the brakes on a toyota dyna 150 - Computers & Internet
  • Jan Rainone
    Jan Rainone Mar 17, 2011
    You posted under computers and printers, please post in Auto, I cannot do it for you or I would, please re-post your question under Automotive Question.
    Thank You For Choosing FixYa~!
3 Suggested Answers
polarcycle
  • 1392 Answers
SOURCE: toyota yaris brakes how do you bleed the brakes on a toyota yaris
have someone pump the pedal and hold it, then you work from the right rear, left rear, right front, left front, while the person pumps and holds several times at each wheel.
Posted on Jun 10, 2009
  • 42818 Answers
SOURCE: what could be the problem for my exhaust brakes from stopping to work on my toyota dyna 1995?
The reason that exhaust brakes on trucks don't work is that the lever for the flap in the manifold is rusted and stuck. It may be that the cylinder that activates the lever is not serviceable or that it is not getting air/vacuum/power to work. Check the switch at the accelerator and the switch in the dash/steering column is operational
Posted on Jun 08, 2014
What could be the problem for my exhaust brakes from stopping to work on my toyota dyna 1995?
Jun 08, 2014 | 2007 Toyota Dyna
Bleed brakes for 2005 prius
release? explain what that means.
what parts were disconnected? MC, tell what you did.
brakes good, bleed, no bad
brakes bad, parts pulled, now bad bleed,???? just a clue.here.
if you open a fitting north of the ABS main unit, you will be in trouble.
did you read the FSM on PRIUS< if not why not>?
got ABS,? sure...
some cars with ABS, have very specail rules and steps for
bleeding ABS. , including factory scan tools that must modulate
the ABS solenoids to clear air !
RTM.
or alldata.com/
i bounce in and read now for you.
it says.
Bleeding the brakes requires the use of the Toyota Hand-Held tester, or other appropriate scan tool. Follow the operating procedures of the Toyota Hand-Held tester, or other appropriate scan tool when bleeding the hydraulic brake system.
Before fiddling any car with ABS, google your car
see what others did wrong.... save lots of grief.
and a tow to a shop.
Dec 22, 2013 | 2005 Toyota Prius
How to bleed rear break on dyna glide bike
Bleeding the brake is not difficult but it must be done in a certain way. Follow these directions exactly. First remove the top from the rear brake master cylinder and check the fluid level. If you add fluid during this process, make sure you are putting the right kind of fluid in the reservoir. It should be printed right on the top cover of the reservoir. Place the top back on the reservoir but you don't have to put the screws in it. All we are going to do with it at this point is keep brake fluid from splashing on your bike. To bleed the brakes, depress and hold the rear brake pedal. Open the bleed valve on the rear brake about a half turn and allow the brake fluid and air to bleed out. Close the brake bleeder valve. Release the brake pedal and check the fluid level in the reservoir. Do not allow the reservoir to run dry. Continue to bleed the brakes until you have a full firm brake pedal. Then top off the reservoir and replace the cap and screws. You can put a piece of small diameter clear hose on the end of the bleeder valves to direct the brake fluid into a catch jar and it makes this job much neater. Do not allow the brake fluid to get on painted surfaces as it can damage the paint.
Good Luck
Steve
Jul 31, 2011 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
I have a1984 F 150 with all new brake parts except the proportioning valve and some of the hard lines which were in good shape. I still have poor pedal pressure and weak brakes after bleeding ,I'm lost
Your not bleeding the system,period
Your working alone or something
Pumping the pedal for no reason
or gravity bleeding,which is it
How are you performing the bleeding?
That is your only problem
Mar 13, 2011 | 1984 Ford F 150
How do i drain my 2005 dyna lowrider's brake fluid back resevoir.
Bleed the brake system adding new fluid until the new fluid comes out in to your bleeding bottle you just changed it.
Apr 09, 2010 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
F-150 brakes are locking up when stopping at low
I was going to suggest bleeding the brakes, but since that is done, try bleeding the master or slave cylinders and check the system for air leaks. Make sure the pads retract sufficiently.
Sep 03, 2009 | 1998 Ford F150 Regular Cab
Toyota yaris brakes how do you bleed the brakes on a toyota yaris
Jun 10, 2009 | 2007 Toyota Yaris
Video on how to change brakes on dyna
you dont need a video there is two bolts on side of brakes on high end at top that crosses over disc after slide axle dont remove wheel slide axle to free up brake mount you can swing it out to work on it with out dissconnecting it from lines remove the two bolts it will require a mutipoint style socket to remove when you take those out the pads will fall out watch closly how the top clips are so when you put new ones in it will go back to gether easy dont bleed calipers press them with a clamp they will move easy install back on wheel and when you cycle your brakes will adjust on there own thank you
Jun 07, 2009 | 2004 Harley Davidson FXDL - FXDLI Dyna Low...
1986 Ford E-150 Brake line problem
when you bleed the brakes start from the p/s rear then d/s and so on make sure to crack the bleed screw and not the bleed nut also check the brake booster for correct movement thats what opens the pistons on the master cylinder
Jun 05, 2009 | 1986 Ford Econoline
Computers & Internet Logo
David Payne
David Payne
