Question about Hotpoint RGB745 Gas Kitchen Range
I have a hotpoint stove/oven model number rgb745beh4ct serial number zg207848r. the stovetop surface is scratched up and has brown stains. can i do anything about the scratches and what type of cleaner can i use to remove the brown stains? thank you
fridgetech
  • 473 Answers
SOURCE: self cleaning hotpoint stove
Sometimes in self clean it can burn out the element.  Need to check the element with an ohm meter and see if it shows resistance.  If it shows open then the element is bad.  If it shows resistance then the element is ok.  Next see if you are getting 220 volts to the element when in bake mode.  If you are not getting 220 volts then the control is bad.
Posted on Oct 21, 2007
tzweeb
  • 318 Answers
SOURCE: glass top is scratched no matter what I do. oven doesn't work ri
glass top stoves are not designed to do canning on, sorry. the only thing you can do for the top is that special cleaner as it has a "wax" in it and will help to prevent stains, but not scratches.
remember your top is glass and it will scratch.
your oven can be calibrated to help it to bake better. what you need to do is make sure you have a temperature problem that can be corrected by calibration. try to just set the oven temps up or down 10 or 20 degrees and try to bake the same items. if this helps then you can reset the calibration of the control as per your owners manual, if you dont have one then i can tell you how if you can tell me the brand and model.
Posted on Jan 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: Hotpoint oven out, stovetop works fine
Reolace the electronic oven control.
Posted on Mar 09, 2009
  • 15 Answers
SOURCE: hotpoint electic stove, the burners and the oven not working
Is there any sign of life? Does the oven light come on or does the clock work? Just for kicks, go and reset the breaker - it should be a double breaker for a 220V appliance - sometimes half will throw and still leave 110v that will run the light / clock.
Posted on Jul 26, 2009
sclarke7
  • 222 Answers
SOURCE: scratches in my flat top Maytag electric range
report the problem as "thermal cracking" and it will be rplaced by whirlpool/maytag,
these things are hard to scratch, cleaning with a FLAT edge razor scraper is the norm, there are dozens of white cream type cleaners that work well with a scotchbrite and elbow grease.
Posted on Sep 04, 2009
Hi I have a GE cafe brand gas stove and decided to clean the burners the other day. I cannot get rid of the brownish stains around the burner. More so, I used the chemical solution that came with the...
always use a non abrasive cleaner solution. so there are no streaks in future. as for now with the brown build up in the workshop we use oven cleaner mr muscle it will lift the grime and not harm the surface. its a little known trade secret
(dont tell anyone else) ;)
merry christmas
please take the time to rank this advice below
Dec 22, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a bad stain on my ceran top stove. It is like a hard glue, which boiled over while steaming broccoli. How do I get this out please?
This has worked for me when I've melted plastic on my stove top, or had other stains that did not come off easily. Use a razor blade to scrape off all you can. Then, when it is cool, use stovetop cleaner (I use Weiman's) and a no scratch scrub sponge. I don't know what your stain is, but the razor blade will probably work.
Nov 03, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Where is the serial number located on stove?
If it is labeled like the other VGIC stoves, the serial number is on the left hand side of the burner box (stovetop). Remove the left side surface burner grates, burner bowl and grate supports.
I hope this helps.
Jul 22, 2010 | Viking VGIC485-6G Gas Kitchen Range
Drexia clarifying previous post on gas range stovetop cleaning.
I have found that kitchen cleanser and a crub pad along with good old fashioned elbow grease is your best bet...
The fine scratches might come out with a good rubbing compound like the type used on car finishes...
Apr 10, 2009 | Frigidaire Gallery 30" Self-Cleaning...
GE Profile Stove, stove top works but the oven will not heat up.
You will most likely have to replace the oven igniter. If you have the model number you posted under, I believe the igniter for the broiler is the same as the oven broiler, and could be swapped out to get the oven working again. (of course, now the broiler won't work until that igniter is replaced) If you'd like the part number or any further advise, comment back with the full model number off the sticker just behind the lower drawer panel on the frame of the range. Tonight, you may have to finish the chicken on the stove top.
Mar 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven proof ???
Hi yes all stone ware is oven proof so you should have no problems using them just remember they stay hotter to the touch for longer than other oven products they stay hotter for longer once their out of the oven let me know if you need further assistance ok
Mar 19, 2008 | Crock Pots & Slow Cookers
Hotpoint RGB745 Gas Kitchen Range Logo
116 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
