Question about Dryers
How do I disconnect a hard wired tumble dryer? It is on it's own circuit but there is just a wire coming out of the wall!
  • 3,018 Answers
First shut the breaker off to the dryer and be sure because 220 can kill you. Now on the back of the dryer is an access panel. Remove that and you will have 3 or 4 nuts with a wire running to each. Remove them and the wires will pull off. As for the other end of the wire, the only way to see where it goes is to remove portions of the wall to see where it goes. It may very well go all the way to the box as I don't see anyone connecting a 220 midway without a socket.
Posted on Mar 17, 2011
Siemens tumble dryer E46.38 no power
if it hasnt tripped a circuit breaker
how old is it
the control board fault
inside the casing and around the drum
some have small sensors with wires
that can be faulty ant stop it heat up and tumble
faulty safety door catch
faulty sealed wall plug
Jun 08, 2016 | Siemens Dryers
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
How to reconnect the wiring on the bosch wta 2000 tumble dryer?
And why did you not tag the wires when disconnecting them as a good repairman always does .
Sep 16, 2015 | Bosch Tumble Dryer Fluff Lint Filter...
Dryer won't heat up during dry cycle
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Jun 09, 2010 | GE DBSR453EBWW Electric Dryer
Miele Tumble dryer will not produce heat .
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Oct 14, 2009 | Dryers
Electric dryer not drying clothes
The electric dryer requires 220 volts to dry clothes but only 110 volts to turn the drum .reset your circuit breaker even if it looks ok ,if that dosent work, unplug from the wall and check where the plug wire goes into the back of the dryer and look for loose or broken wires.
Apr 26, 2009 | Estate TEDX640JQ Electric Dryer
Roper Dryer heats for 5 minutes then stops heating but still tumbles. I haven't a manual so there isn't a schematic to work with. Appreciate any suggestions;
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Sep 14, 2008 | Roper REX3614KW Electric Dryer
Maytag MDE2400AYW Dryer Heating Elements not staying on
Heating element
Thermal fuse
Wiring
Jul 30, 2008 | Maytag MDE2400AYW Neptune Electric Dryer
No heat?
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 06, 2008 | Danby DCD5505W Electric Dryer
My whirlpool tumble dryer keeps tripping the circuit breaker
if it trips it off immediately after starting or wont even let you reset the breaker, you have a direct short(wire off a terminal ) or your heater element has broken and is hitting against side wall
Mar 24, 2008 | Dryers
Dryers Logo
434 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
