Question about FileZilla Project FileZilla Server
I try to upload a php file to a folder; It tries until timeout, then says that the file I tried to upload already exists, and do I want to overwrite it. The file wasn't there before, and is now 0 bytes. I select overwrite, and it tries again until timeout, and then it fails. Details: Domain - benjaminrharris.com Host - Bluehost Port - default (21 I think) Username & Password provided ok FileZilla allows me to access the folders and directories, and chmod things, it just won't let me actually upload or download or edit files. Thanks so much!
    Habit-Forming:
  • 64 Answers
I would check the FileZilla FTP Settings to make sure the "Passive FTP" is not enabled.
In "FileZilla" it's under "Edit", "Settings", "Connection", "FTP". Change from "Passive" to "Active".
Hope this resolves your issue
Posted on Mar 17, 2011
Testimonial: "Great! Perfect! It fixed the problem perfectly, and it took me about 2 seconds; easy instructions. Thank you so much!"
I am devising courses for a 4 day tour but every time I upload a new day it overwrites the already saved one. Help
change the names of the files, do not upload materials using the same file name. ... if this is possible. It might be that memory is full so it has to overwrite?
Jun 08, 2015 | Garmin Edge Touring
Tip
Have you had problems with enabling FancyUrls in your CMS (Content Management...
Have you had problems with enabling FancyUrls in your CMS (Content Management System)? A lot of hosts don't have mod_rewrite enabled, or even a basic .htaccess file.
This simple fix is just clearly written to help users better understand what to do, as well as an easy copy/paste job.
  1. Simply copy and paste this code into a new Windows notepad file.
  2. "Save file as.." .htaccess - including the dot in front of htaccess.
  3. Upload the file to your public_html directory, overwriting the previous one if any.
  4. (Not a required step, use only if temp.htaccess exists.) If there is one called temp.htaccess, simply delete that one OR rename it as .htaccess and upload the new .htaccess for an overwrite.
Copy the text below this line..
AddDefaultCharset UTF-8
Options +FollowSymlinks
RewriteEngine on
RewriteBase /
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule /?([A-Za-z0-9-]+)/? $index.php?id=$1
# Add a ReWriteBase line to any directory or subdirectory requiring it.
# The default directory is "/", which is the root or main directory you use.
------------------------------------End copy
Good luck to you!
on Jul 04, 2010 | Computers & Internet
Tip
Simple Mod_Rewrite Codefix(Virtual Directory hosts only)
A lot of hosts don't have mod_rewrite enabled, or even a basic .htaccess file. Keep in mind this is for people using a blogging system or small Content Management System, such as Wordpress or GetSimple.
This fix is clearly written to help users better understand what to do, as well as an easy copy/paste job.
RewriteEngine on
RewriteBase /
Good luck to you!
on Jul 03, 2010 | Computers & Internet
Uploading files
More information needed. Where are you trying to upload to, what files etc.
Sep 09, 2013 | Dell Inspiron Computers & Internet
Tried to install the free map update/upgrade(North America) on my new XL 335-S and now have no maps at all. The install showed an error and now when I try again, I am notified that there is not enough room...
There is this problem with TomTom. Tom do not seem to overwrite the existing map file. So before trying to install the map, you need to delete the folder containing map. Once you have connected your TomTom to the computer, close the TomTom home window. Double click on my computer. You will see the TomTom hard drive as a drive (like you see the CD drive) double click on that . Once the folders of the TomTom hard drive opens, look for a folder named USA_Canada_and_Mexico_P. Right click on it. click properties. Check whether the size of this folder is approximately around 1.3 GB to 1.5 GB. This is just to make sure we have the correct folder. After confirming this is the map folder, copy this folder to your computer for back up purpose. Once you have it safely in your computer, delete this folder from the TomTom hardrive. Go back to TomTom home software. Use the map guarantee to update/Upgrade the new map. You will see this time around the installation completes without a problem.
Apr 23, 2010 | Tomtom ONE XL-S GPS
I purchased a memorex 160GB traveldrive. I would
Things to ponder before deleting
Rather then deleting them right away, try moving the "day the files were uploaded" to another drive. Then try accessing the files on your memorex. Do the files and folders open properly? There not corrupt? Has the memorex hdd drive recreated the folder you just moved? etc...
Once your satisfied that yes there are two copies then you could safely remove one.
Nov 07, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Can't create new folder on memory stick
Sometimes these things get confused. try moving everything to a folder on your machine then, use the SanDisk tool to format the flash drive and move everything back.
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Putting new songs on instinct that are already there?????? please
Even if they do exist, just do overwrite all. Make sure you do it in the music folder. Whenever you try to copy them onto the phone, just do overwrite.
Jul 26, 2009 | Samsung Instinct Cell Phone
Been having this problem for 2 months.. computer is turned off... have been rebooting from CD in drive for 1 year... harddrive tired and cannot boot up by itself... lately cannot get to any Recovery mode,...
If you have a Windows XP CD, follow these steps.
1. Boot from the CD and start the installer
2. Choose to install onto the already formatted partition with the unbootable Windows, but opt to leave the existing filesystem and any other OSes alone. Choosing this will require you to create another folder for Windows to avoid writing over the existing installation. I usually call the new folder "WINXP."
3. Install Windows as you would normally, you'll need a Product Key but you can actually use your personal key on someone else's computer with no danger to you losing it or being accused of piracy, I'll explain this later.
4. Boot the NEW Windows XP install. Do not "Activate" or "register," you're going to be deleting this copy of Windows from the machine if all goes well.
5. Edit the BOOT.INI on the hard drive from the original installation of Windows with the corrupted HAL. This file should be in C:\ (may be hidden)
Sample BOOT.INI for XP Pro
Microsoft wrote:[boot loader]
timeout=10
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /NOEXECUTE=OPTIN /FASTDETECT
6. Go to C:\WINXP\system32\hal.dll (where "WINXP" is the folder you installed the second copy of Windows XP) and copy it from the new Windows to C:\WINDOWS\system32\hal.dll (or wherever you installed Windows XP originally, I use "WINDOWS" but some people use strange folder names for their XP) and overwrite any file there. The new hal.dll is uncorrupt and newly regenerated. The file is specific to each machine's hardware configuration and we needed to rebuild it. The installer did that for us with the new installation.
7. Try rebooting your computer to see if you can get into your OLD Windows installation. If you can, congratulations!
8. DELETE the "WINXP" folder (or wherever you put your new Windows install).
PS: Please rate this solution
Mar 11, 2009 | Computers & Internet
Driver downloading
If you could tell me what the name of the file you are downloading is called I can give you step by step instructions on how to install them. Thanks!
Sep 25, 2008 | Computers & Internet
Computers & Internet Logo
Top FileZilla Project Computers & Internet Experts
David Payne
David Payne
Are you a FileZilla Project Computer and Internet Expert? Answer questions, earn points and help others
