Question about Microwave Ovens
My adsl2 is giving much lower speeds than expected ie 50 to 500kbps against an expected 2-3000kbps at my location. (Actually the Intermode map forecast 7000kbps.) Where can I go to find someone I can pay to have a look at it for me? The Telstra phone help is useless. Really need help and not looking for freebee! Thanks, Bryan Nolte
  • 1,512 Answers
Hi nolt
Can you go to this speed test and see what you clock?
robotek
Posted on Aug 02, 2008
    Brigadier General:
  • 6,966 Answers
I am assuming you are somewhere in Australia, this site has several experts from Australia. Perhaps you could ask them directly through the "Ask Me". Some of them are:
  • robotek
  • Nickstar19
  • chris07551
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Small metal-like plate against wall smokes when I try to use the microwave. Bought it last year. Afraid it will cause a fire so I don't use it. Pregnant with twins..need my microwave.
Shelley,
That is actually a mica plate and that can be replaced. I would suggest trying to find an appliance repair store near you and give them your make and model number of your microwave and they can probably order the part for you. Worst case scenario would be that you might have to order a piece larger than you need and you would have to trace out your old one onto the new one and cut it out yourself. It is not hard to do. What happens, is food grease gets splattered around during cooking, and it can get built up behind that plate and it will start to smoke after a while. You could try removing the plate and cleaning both sides real well, and if it has not charred the plate on either side, you might be able to get by with putting it back in. Hope this helps!
May 19, 2015 | Microwave Ovens
Where is the fuse located
How do you expect us to know where the fuse is located without telling us the brand and model number of the microwave oven? They are NOT all the same!
Oct 16, 2014 | Microwave Ovens
Defective microwave door switch?
You are correct about the upper switch if normally open resistance infinity, but when switch is depressed resistance should read near 0 ohms, you need to change the door switch. Now the high voltage diode cannot be checked with a digital meter because the bias is to high, chances are it is okay.
May 11, 2012 | GE JVM1850 1000 Watts Microwave Oven
What is the temperature attained inside the microwave oven in a time span of 100seconds if the rating of the oven is 1200watt ?
The mass of the material you are heating affects the temperature achieved. ie. 2pints of liquid will reach a lower temperature than 1pint in 100 seconds.
Sep 06, 2011 | LG LMV1630 Convection/Microwave Oven
The freezer part is working fine ,it seems as tho the refrigerator part is warming instead of cooling
The freezer is actually where the cold originates and is passed through into the refridgerated area.
Open the fridge doors and check that the air passage is not blocked by something stored against it. It's probably on the top shelf and looks like a louvre vent. There may be another down by the crisper drawer
Aug 14, 2011 | Microwave Ovens
GE microwave. Model WES1450DM1BB. Power after the fuse runs through a sensor which rests against the metal chasis. If sensor is bypassed mircrowave works fine. Sensor evidently is open. I cannot find any...
If the part is located near a potential 'hot-spot' it may be a thermal device and possibly a thermal fuse. Once opened, they don't self-heal.
If you describe the part, I may be able to identify it better.
Dec 14, 2009 | General Electric Microwave Oven
Noise of microwave exhaust fan
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
Mar 25, 2008 | Microwave Ovens
Infrared toast
Is the element glowing on the other side? Is the unit being used correctly ie, the correct toast setting versus 'top brown'?
Mar 10, 2008 | Microwave Ovens
Microwave Blower Fan - One Speed Only
We see this a lot. The problem is probably on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 02, 2008 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
