Question about NetGear WGR614 Wireless Router
Can not login?
I tried many times to login but it still couldn't.
Is there another way to login?
Thank you.
Irene
    Brigadier General:
  • 6,966 Answers
Initially, verify that you are connected by wire/LAN to the router and try 192.168.1.1.
If that doe not allow access to the web configuration page, perhaps you need to try to do a reset. The reset back will revert the unit back to factory settings (assuming no hardware or firmware fault). This is done by inserting the paperclip into the reset hole on the rear panel of the unit for more than 10 seconds.
An alternate method is:
Press and hold the reset button for 10 seconds without the power cable plugged in. And while holding the reset button, plug in the power cable and keep holding the reset button for about a minute and then release it. You will have a check light (if any) in the router. After resetting the check light should go OFF.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 02, 2008
  • 659 Answers
These steps solve most of the problems with logging on to routers.
  1. Connect a computer and a router directly with an Ethernet cable, putting an end in one of the router's LAN ports. Check that both ends are secure.
  2. Check the Internet LED is lit. If it is not, troubleshoot the light status, as explained in the manual.
  3. Check that the LEDs for the ports with cables are lit. If they are not, try moving the cable to a different port. If there are still no lights, then troubleshoot the light status, as explained in the manual.
  4. Check the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue with this document. If the Ethernet adapter was not made by NETGEAR, contact the adapter's maker.
  5. Select Start > Run. Type cmd. Type ping 192.168.1.1. If there is a message "Request timed out", type ping 192.168.0.1. If that also has a "Request timed out" message, then your computer is not making a connection to the router.
  6. Otherwise, your computer is connected to the router:
    • Make sure proxies are not enabled. If using Internet Explorer, select Tools > Internet Options > Connections > LAN Settings. Uncheck "Use a proxy server for your LAN....".
    • Delete offline contents. Select Tools > Internet Options > Delete Files. Select Delete all offline content, and click OK. (This is to clear any possible previous router log on page.)
    • Try accessing with a different computer, or with the Netscape browser, if you have it.
    • Delete cookies. WARNING. Do not do this if it's possible Web sites you visit need cookie information such as your logins and passwords.
  7. Power off the router, and power it back on again.
  8. If you still cannot log on to the router, then do a hard reset on the router.
  9. If you know how, check the computer's IP address and DHCP. The IP should be in the 192.168.0.x range, and DHCP should be enabled.
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
At the time of opening indiana jones and the tomb emperror s written message: abort couldn t open game library. r parameter d3d.dll.make sure your game is set And that the file is present in your bin...
abort couldn t open game library. r parameter d3d.dll.make sure your game is set And that the file is present in your bin directory solution .. please thank you very much
Nov 23, 2011 | LucasArts Indiana Jones and the Emperor s...
I couldn´t run and schtask command send the
Did you tried to login as administrator account or do you have admin rights on the machine you are trying to schedule tasks.
Aug 12, 2009 | Citrix Computers & Internet
I HAVE AN ORKUT ACCOUNT,BUT I COULDN,T OPEN MY ORKUT PAGE PAGE
Either your internet connection is slow or your account has been hacked..try the forget password option under login ...and give your details to get your new password
Jun 07, 2009 | Computers & Internet
I can't login to my Yahoo Messenger app
update your device date/time (option-->date/time-->push BB-->update time
Apr 26, 2009 | RIM BlackBerry Bold 9000 Smartphone
Freeing myn d drive
try chifting all the files u needed to another drive and format the D drive...
Sep 26, 2008 | Computers & Internet
Briel chamonix instructions
I work at Briel USA. Please send your email address to me requesting a manual for a Chamonix and I will send you one via pdf.
irene@smithagy.net office phone 770-509-3006
Also,you might find what you need at the Briel USA website at: www.smithagy.net click Briel.
Please let me know if you need anything else.
Thank you.
Best Regards,
Irene
May 29, 2008 | Briel Chamonix ES-35 Espresso Machine
Garage door feature for ford 150
Irene, go to this website:
http://www.homelink.com/training/train.taf
Select what you are trying to do and for what vehicle and garage door opener manufacturer.
Hope this helps!
May 15, 2008 | 2004 Ford F150
NetGear WGR614 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
