Question about Philips Sport Personal CD/MP3 Player
Mp3 how do i reset my phillips SA411X
  • Anonymous Sep 25, 2008
    i have the same problem
  • Anonymous Jan 29, 2009
    same
My phillips Sa411x won't read on my computer
Posted on Aug 30, 2008
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
My Phillips GoGear 16GB won't come on.
I have a phillips go gear 8 MGB.numbers on inside of mp3 is 4901v3.68 and sstm12 080929 . I have tried reset & charging it but nothing will make it turn on. I spent alot of money on this thing for it to work a short period of time.What can I do???????????
Apr 14, 2010 | Philips GOGEAR SA6045 MP3 Player
Will not play the music
reset it by pressing the reset button (pinhole)using a pin
Dec 31, 2009 | Philips Audio Players & Recorders
My phillips gogear 8gb mp3 player will not come on at all after trying to sync to put music on it
Please try pushing your reset button and see if it comes on. You may need to read your manual to see where the reset button is.
Sep 15, 2009 | Philips GoGear HDD1830 MP3 Player
Phillips Gogear SA5285/37 is frozen
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
Phillips gogear is frozen
Press and hold the Power On/Off key and the Volume + key for a couple of seconds to reset
If that alone fails, run a Repair in the Philips Device Manager
-Tha Mp3 Doctor
Dec 27, 2008 | Philips GoGear HDD6330 MP3 Player
How to start power and off the power
Reset the player by using a #2 size paper clip and inserting it in the reset hole. Then it should turn on and off properly. See manual for details.
-Tha Mp3 Doctor
Oct 23, 2008 | Philips GoGear SA178 MP3 Player
I dot know how to reset my phillips SA411X
Hi - You can download the manual from the link underlined in blue below:
phillips SA411X
So to reset remove & replace the battery.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 02, 2008 | Audio Players & Recorders
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Help me
Go to the Phillips website to find out the button combination to reset your player. I have a Phillips mp3 player, and I have to reset it every once in a while. If that does not work, call Phillips support.
Apr 21, 2008 | Philips GoGear SA178 MP3 Player
Philips Sport Personal CD/MP3 Player Logo
220 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
