Troy Bilt Tb70ss Gas Trimmer Logo
Posted on Mar 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello. Up to now, this trimmer has been great. The problem I have now is that it continuously feeds line. It takes about 2 minutes to use the entire spool.
Charles Huckeba
Level 2:
Genius:
  • Expert 1,114 Answers
  • Posted on Mar 17, 2011
Charles Huckeba
Expert
Level 2:
Genius:
Answers
1114
Questions
0
Helped
322080
Points
316
When this kind of thing happens, you will need to replace the spool head. That will stop the issue. You can pick up one at your local hardware store, or Lowes/HomeDepot.
Echo SRM225 line trimmer continually feeds line
If the line feeds with out bumping it nay be the line gas been put on the wrong way
Apr 30, 2017 • Echo Garden
My black and decker grass hog wont last about 5 minutes and the line empty?
Have you tried re assembley? take it apart and completely redo the whole line reel. i f this does not work. Contact Black and Decker online.
Gh1000
There is a spring inside the button on bottom. If it is missing broken or not seated properly the line will feed continuously.
First try tapping the bottom to set the button. Then inspect the line feed assembly.
good luck
2helpful
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 • Garden
Why is line feeding out too fast on 503a
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, !!
Jan 29, 2012 • Garden
How do I change the line on my 25 cc homelite zip start trimmer
1) Use a pair of vise grips to open the wheel on the bottom of the feede;
2) Remove the wheel, taking care not to lose the screw inside it;
3) Remove the outside wheel, feed line into one of the interior wheels and wind it around until the wheel is full following the direction of the arrow on the outside. Leave enough line (4 - 6") to feed out the holes;
4) Repeat for other wheel;
5) Replace wheel, feeding excess line into outside wheel holes on wheel frame still attached to weedeater;
6) Hold wheel together tightly and reattach wheel hub. Hand tighten only as it will tighten itself with use and require vise grips to remove again.
Hope this helps.
2helpful
2answers
My weedeater with auto line feed will not stop feeding the line when in use.
Did you ever get an answer to this problem? I'd like to know because I have the same problem with my cordless 14" Black N Decker Gass Hog. I rethread it, but the line continually feeds and is out in about 2 minutes.
How do i adjust the homelite carburetor , the trimmer starts and continue working but has no power to cut the grass
if you have had this trimmer for a wile you might check the little muffler to see if it is cloged up with carbon i had on and adjusted the thing till i was blue in the face and pulled the sreen of the muffler cleaned it now it runs great
3helpful
String continuously feeds and cuts
sounds like something is out of place. try again.
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
