Question about Brother IntelliFax-2820 Laser Fax
Replaced drum fax 2820
I had just replaced drum for fax 2820. But whet I put it into a machine. It still on the LCD the word " Change drum soon" . Please help me hoe to slove this problem.
Thanks
  • tractorl Aug 04, 2008
    Dear sir !
    Thank you very much .
    I had sloved this problem
    " I had just replaced drum for fax 2820. But whet I put it into a machine. It still on the LCD the word " Change drum soon" . Please help me hoe to slove this problem. "
  • 148 Answers
Hi, #'s 6, 7 and 8 below explain how to reset the drum indicator.
Hope that helps...
Lbcoaster
How do I replace the drum unit?
Description:
Follow the procedure below to replace drum unit.
CautionDo NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
Replaced drum fax 2820 - spray1.gif Caution
    Just after you have used the machine, some internal parts of the machine are extremely HOT! Never touch the shaded parts shown in the illustration.
  1. Open the front cover and pull out the drum unit and toner cartridge assembly.
Caution
    To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  1. Hold down the lock lever on the left and pull the toner cartridge out of the drum unit.
Note
    • Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
    • Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag.
      1. Unpack the new drum unit.
      1. Reinstall the toner cartridge into the new drum unit. If you put it in properly, the lock lever will liReplaced drum fax 2820 - all-ug-16.giflly.
      all-ug-16.gif Caution
        To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
        If you accidentaly touch the shaded parReplaced drum fax 2820 - drum_2000.gifurface with a dry lint-free soft cloth.
      1. Install the drum unit and toner cartridge assembly in the machine.
        1. Press Options.
        1. To confirm you are installing a new drum, press 1.
        1. When the LCD shows Accepted, close the front cover.
        Related Models FAX-2820, FAX-2910, FAX-2920, MFC-7220, MFC-7225N
Posted on Aug 02, 2008
What you described doesn't really solve the problem. you are just describing how to change the drum. of course that will reset the "change the drum soon" problem...
i thought this is more a hack then a how to change the damn drum...
Posted on Oct 20, 2008
Dear Fixya !
I have sloved this problem .
Thank you very much
Tractorl
Posted on Aug 04, 2008
CHANGED DRUMAND THE CHANGE DRUM SOON ERROR IS
you need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Change drum soon
Open the front panel.Press and hold the clear button.When "Drum replaced"shows on the lcd panel select yes.The message will be reset.If you experiece any lines in the future you will have to replace the drum catridge.
Mar 12, 2010 | Brother IntelliFax-2820 Laser Fax
HOW DO YOU TURN OFF DRUM LIGHT ON BROTHER 2820
Open front cover....press 'options', and select 'new drum'
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Nov 13, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Apr 23, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
804 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
