Question about La Crosse Radio Controlled Atomic Clock
I need to reset my clock for time change and have tried removing batteries and pushing set button without any change to clock. What do I do when batteries are engaged and the clock numbers are flashing 12:00?
    Brigadier General:
  • 8,546 Answers
Http://www.timex.com/info/Product_Instruction_Guides_Downloads
Many downloads here, find yours.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
Posted on Mar 18, 2011
How to change the time on my 2003 ford explorer
It should be in your owners manual. Depending on which radio you have, you either turn the radio off, push the clock button, then advance the time with the seek or tune button - or - push the clock button and put the time in using the number buttons then push the clock button again to store the setting.
Jul 26, 2012 | 2003 Ford Explorer
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
I have a RCA clock model RP5435C that will not switch over to daylight savings time...what should I do. I have already tried unplugging it, but that didn't work.
if the clock radio is coming back on without being plugged in or still has the time on it when plugging it back in, it probably has a backup battery, take the battery out. Why can't you just reset the time to the correct time, just push the time set button, then the hour button, etc.
Mar 13, 2011 | RCA Audio Players & Recorders
I have a digital wall timer that allows for settings over multiple days. Trued to reset it (remove a few memorized settings) by pushing 'reset'; but this had no effect. Do I need to press it for a longer...
You posted the question under ST01C timer.
This timer will clear all programs if you hold reset in for a few seconds until the screen starts blinking 12:00. The reset button is a small round button that you push with a paper clip.
The ST01C memory for current day can be cleared by removing battery for a couple minutes, but the day-to-day programming remains forever until timer is reset.
Each timer tends to follow the same pattern as described above when there is a small round reset that is pushed with a paper clip >> push, hold for a few seconds, timer resets.
Other timers have a larger button for Reset ... the timers with larger reset button usually require you to hold the clock button and reset button at the same time ... or some other button besides clock has to be pushed at same time with reset. You can try different combinations of buttons and hold both down for a few seconds.
If you reply to this response with your exact model and brand timer, I can look up the specifics for most timers
Oct 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Changing the time
you can go to http://www2.oregonscientific.com/assets/manuals2/bar338pa.pdf to see or print the user's manual.
If you don't want to get the manual, here's what you do to fix it. . . . .
*note: you need to do this anytime you change the batteries.
1) open the battery cover
2) on the left side you'll see 3 little buttons labeled a)zone, b)C/F c)reset
3) push the reset
4)push the zone button until your time zone is highlighted on the front display
5) look at the front display & if you see a blinking "radio signal" icon at upper left of time numerals
don't do anything else. The time, date, etc. will automatically synchronize your clock with the US Atomic Clock. This could take up to 10 minutes. As long as the "radio signal" icon is blinking, it's working on it. When the icon doesnt' blink, it's set. Cool, huh?
6) if the area you live in can't receive the signal from the Atomic Clock, instead of a blinking "radio signal", you'll see just a bare antennae. Since you probably set your clock manually, that's what it shows now before you do anything.
7) after you push reset & set the time zone do NOT touch any other buttons to set anything!!! (I know it's difficult to leave things alone, but just sit on your hands). Pushing the "clock" button or the up & down arrows will stop the radio signal & change to manual functions. Look at the signal icon mentioned in 5) and 6) above. If you only have the bare antennae icon. . . . . go ahead & set the time/date yourself. You have no signal.
Enjoy your clock!
debkresh
Jan 25, 2009 | Oregon Scientific FM Weather Projection...
Setting the clock
You need to hold down both the reset and the select buttons until the clock starts flashing. Then push the select button to adjust the hour. Then push the reset button to make the minutes start flashing, push the select button to adjust the minutes. Once you have the time set correctly, push the reset button one more time. You should be done.
Jan 10, 2009 | 2007 Yamaha Royal Star Tour Deluxe
Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Nov 02, 2008 | Audio Players & Recorders
Resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Dec 01, 2007 | Baby Gear
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
La Crosse Radio Controlled Atomic Clock Logo
253 people viewed this question
Top La Crosse Home Experts
David Burbee
David Burbee
Are you a La Crosse Home Expert? Answer questions, earn points and help others
