Question about Realtek Semiconductor Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC
Download drivers RTL8111C Gigabit Ethernet Controller Version: 6.198.1003.2007
  • 977 Answers
Hi!
You can download the LATEST version from here...
Regards,
Pelu.
Posted on Mar 17, 2011
Driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
Sep 18, 2012 | Dell J0592 / 0J0592 DIMENSION 4550...
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Can not find Driver bcm5701 gigabit ethernet driver for xp
Hi!
You can get it from here (32-bit version) or here (64-bit version)...
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
May 29, 2011 | Broadcom BCM5704 10/100/1000BASE-T...
Ethernet controller for msi k9n6sgm-v
If you are trying to connect through a modem/router you it should have come with a disk then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
May 25, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I'm not able to connect with my ASUS M50vm to ethernet. how i can check if the hardware is working?
May 16, 2011 | ASUS Intel 440BX Chipset P2B-VM...
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
Apr 30, 2011 | Televison & Video
Need drivers for ibm 10/100/1000mbps gigabit ethernet low profile pci express adapter Item#53y4005-co
This card is equivalent to the
Marvell Yukon 88E8075 PCI-E Gigabit Ethernet Controller
This should be the correct driver:
http://www-307.ibm.com/pc/support/site.wss/MIGR-74413.html
Follow the instructions at the site.
Apr 11, 2011 | IBM 10/100/1000Mbps Gigabit Ethernet Low...
Hello, i re-installed my Xp and got myself a problem.... I've lost my original motherboard driver cd and i had to download them from biostar site... all the drivers I found on theirs site worked fine but...
The network chip on this motherboard is a Realtek RTL8111C.
The XP driver for this chip can be found on this page:
http://218.210.127.131/downloads/downloadsView.aspx?Langid=1&PNid=5&PFid=5&Level=5&Conn=4&DownTypeID=3&GetDown=false#RTL8111B/RTL8168B/RTL8111/RTL8168%3Cbr%3ERTL8111C/RTL8111CP/RTL8111D%28L%29%3Cbr%3ERTL8168C/RTL8111DP
Hope this helps,
Chris
Mar 01, 2011 | Biostar A770 A2+ Motherboard - v6.0, AMD...
Reloaded Windows XP on computer but apparently lost the ethernet drivers. Downloaded drivers but Wizard cannot find them. I know where they are but Wizard won;t let me select the files, Help!
http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Ethernet+Components&ProductLine=Ethernet+Controllers&ProductProduct=Intel%c2%ae+82573L+Gigabit+Ethernet+Controller
http://download.cnet.com/PCI-Ethernet-Drivers-version-A01/3000-2112_4-109142.html
Hope this helps.
If this helps you resolve your problem, please
consider giving a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 24, 2010 | Computers & Internet
Ethernet controller
More than likely this is the one that you need. It is for a Broadcom NIC. If that one doesn't work, they have this one for a Gigabit NIC listed here. I would start withe the integrated NIC divers. Both files have download instructions on the page if you need it.
Hope this helps. Please remember to rate this information.
Thanks
Jan 05, 2009 | Dell Dimension 2350 PC Desktop
Computers & Internet Logo
900 people viewed this question
Top Realtek Semiconductor Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you a Realtek Semiconductor Computer and Internet Expert? Answer questions, earn points and help others
