Question about Whirlpool Duet GHW9150P Front Load Washer
Washed a load of cloths and when I went to take them out the cloths at the bottom were standing in a small amount of water. ran them thruogh a spin cycle and took them out. The next morning the drum was full of water almost up to the door, What could have caused this problem? Thankyou
    Brigadier General:
  • 6,277 Answers
This is symptomatic of an intermittent (hot, if it's hot and cold fill, cold if it's cold only) water control valve- it is not closing completely so it needs replacing! Service call ;-0(
Good luck,
John C
Posted on Mar 17, 2011
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
When i spin wash tub wigth my hand i can hear lots of water still in the machine under neath the wash basin
That is becouse most washing machines are made up of an inside drum where your clothes are washed and an outside durm that catches the water when the washer spins the water out of the washed clothes. A pump is connected to the bottom of the outside drum. If the pump fails, the water would not get pumped to the drain and would collect in the outside drum.
Aug 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washed clothes while on the 'clean washer' setting
I'm sure that the exact make up of clean washer or tub clean cycles vary from brand to brand, but basically that cycle fills to a higher water level, hottest water, and highest spin, turning off load sensors / out of balance sensors so the machine can spin with water in the tub (allowing tub cleaning agents to contact all tub surfaces). (all other cycles pump the water out before spinning) Having a load of clothes in the machine at this time could result in overloading machine (gererally causing an error code), damage to suspension components, damage to hoses or connections resulting in water leaks, etc. Due to the large water level, your clothes would be agitated more ****, but the hot water might damage some fabrics. A FixYa rating would be appreciated for this info. Thanks.
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Mildew/Stagnant water smell in washer
you know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Feb 18, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Oct 15, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
